Old 10-04-2008, 10:32 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
how are you routing your transmission lines.
I'm thinking of re-doing my transmission lines and would like some ideas. Are most of you using the stock hanger on the engine oil pan?
What is the best way to do this? Make your own or buy them pre-bent?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 10-04-2008, 11:08 AM   #2
steelhorse
steelhorse's Avatar
Re: how are you routing your transmission lines.
I am using the factory ones from the 87 I got the trans out of.I plan on redoing the ends to fit whatever radiator I get.
steelhorse is offline   Reply With Quote
Old 10-04-2008, 11:58 AM   #3
big_al_71
big_al_71's Avatar
I made my own. Mine run on the frame all the way to the front connected directly to the tranny cooler. I am still reassmebling my truck I will take some picts of exactly how I ran them and hopefully it will help you...Here is one pict of where they come out in the front.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-04-2008, 12:04 PM   #4
Sport/Truck
Sierra Grande Club
You are using rubber fuel line?
s/t
Old 10-04-2008, 12:09 PM   #5
big_al_71
big_al_71's Avatar
s/t
NO!!!!!!
That is hydraulic hose specific to run oil in it....
Old 10-04-2008, 12:20 PM   #6
Sport/Truck
Sierra Grande Club
NO!!!!!!
I should have guessed that one.
How did you do the connections? The hose has a crimp to adapt it to the metal lines?
s/t
Old 10-04-2008, 12:27 PM   #7
1972CST
1972CST's Avatar
Advance auto carries a kit to us 5/16 trans cooler hose. The kit has all the hose fittings w/ barbed ends w/ the correct flare fitting. I was thinking about going this route if I cant find any factory steel lines.
1972CST is offline   Reply With Quote
Old 10-04-2008, 02:01 PM   #8
Sport/Truck
Sierra Grande Club
I'm willing to check it out, but what what is the sister company's name? We have Checker, Autozone, pep-boys, Carquest, Napa.
s/t
Old 10-04-2008, 02:43 PM   #9
1972CST
1972CST's Avatar
I have checked Autozone and they dont have it here. We dont have those other stores close by.If any of them have a section w/ trans coolers and related parts then they will probably have them. I think the brand is either Imperial or Hayden.
Old 10-04-2008, 03:37 PM   #10
big_al_71
big_al_71's Avatar
s/t
I am using XRP Ain connectors on both ends at the tranny and at the cooler. I will post picts of it on monday...
