Old 10-07-2008, 12:46 PM   #1
rci2990
disc brake conversion
im doing a db conv. on my 70 and im gonna use the 70 upper and lower orig. control arms.i got stock spindles off a 72 i got 2 questions.can i just buy the moog upper and lower ball joints for a 72.and i read something some time ago about possibly grinding the stop on the db spindles so that it moved fully from lock to lock.oh and one more question regarding the outer tr ends,do i have to change just the outer or both outer and inner.thx
1970 c-10 2wd longbed
rci2990 is offline   Reply With Quote
Old 10-09-2008, 12:30 AM   #2
rci2990
Re: disc brake conversion
bump
Old 10-09-2008, 07:01 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
The original tie rods won't work with those spindles. You can get outer tie rods for the 72 and buy a special adjuster sleeve that will fit the original inners and the 72 outers. I'm sure the vendors on the board sell them. The ball joint diameters are the same IIRC; the only difference is the taper/length of the stud. When I did mine I used the parts from an '89 burb. I just swapped the control arms over and u-bolted them to the original crossmember. Then swapped in all new burb front end parts. I thought about going the route you are doing but I ended getting the burb for next to nothing. Hope this helps.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
