Old 10-09-2008, 08:32 AM   #1
Scott Johnson
Junior Member
Scott Johnson's Avatar
Will this work
I have access to a 76 4wd chassis. Will my 71 body and bed fit this chassis?
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 10-09-2008, 11:39 AM   #2
nightmare
nightmare's Avatar
Re: Will this work
with modification to the 76, yes, it should fit.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 10-09-2008, 10:15 PM   #3
woodwright
Enjoying left field
woodwright's Avatar
Re: Will this work
I tried this before, there is a difference in wheelbase. I can't remember which way it goes though.
woodwright is offline   Reply With Quote
Old 10-09-2008, 10:27 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: Will this work
I think you'd be in for a lot of work, not just a simple bolt and go deal.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 10-09-2008, 10:32 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Will this work
assuming LWB, the 76 is a 131 inch wheel base verses the 127 on the 71.
You'll have to relocate the rear axle, since the frame isn't flat like the 71, you'll have to make a custom lift kit to lift the cab up to the bed
possibly fab up all the cab/core support mounts
It's doable, and has been done. Mudder has a square body frame under his red stepside.
Old 10-10-2008, 08:47 AM   #6
Scott Johnson
Junior Member
Re: Will this work
Thanks Guys, got in touch with Mudder, and he told me what I needed to do.
