Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 10-11-2008, 06:29 AM   #1
Robert Paul Thomas
1967 C-10 SWB LS-6 T-56
WIW best of best
67 SWB chev from arkansas, wood bed, small window. Frame blasted, epoxied, painted semi gloss black. ECE 5/6 drop kit, super trackbar, shock relocation, crossmember, rear crossmember, stainless gas tank, trans mount, front disk brake kit. 98 LS1 with 46k/ T-56 sixspeed. S&P headers, Air filter/MAF, speedo modification from DSS to cable, and engine mounts. Mcleod shifter relocation kit with hurst shifter. Dennys alum driveshaft,SLP flywheel, centerforce pressure plate/ clutch, GM hydrolic clutch, and bushing. New bearing and seals in trans. In line tube stainless hard lines, flex lines and cables. Russell gas lines/ S&P fuel filter/ GM hi vol electric pump. Moog upper and lower ball joints, inner and outer tie rods, upper and lower shaft kits. New drums, raybestos pads, wheel cyl, combi kits. New eaton posi/ 373 gears, timken bearings, seals, moser axles 5/5. New good year 255, 275 17 tires on new torque thurst II 17 inch. All ass with gold cad/ nylock bolts.2 1/2 magnaflow custom tig welded stainless exhaust.
The following list is NOS GM, not repop l/r fenders, l/r inner fenders, grill, grill inserts, 2 sets grill hoops, 2 sets headlight bezels, gravel pan, hood latch, hood latch catch, parking lamps/ 2 sets of lenses, 2 sets chevrolet hood emblems, hood bumpers, hood hinges, firewall wiring harness, rad support, front bumper brackets, front frame bumper brackets, drive and 2 pass wiper trans, wiper motor, dash bezel, a/c control/switch, ingition switch/bezel/cylinders/keys, wiper switch, headlight switch, amp guage, gas guage, temp guage, tach, ash tray, lighter, glovebox light, spid label, glovebox bumpers, windshield weatherstrip w/stainless trim, back glass, door seals, inner and outer felts, vent window seals, vent window handles, door opener trans, latches, catches, 71/72 mirrors, gasket and bases, 2 sets door custom script, 3 C-10 emblems, grill bowtie, door sills, inner box tubs, tailgate, tailgate handle, tailgate trunions, tailgate latches, rear bumper brackets, filler panels, license plate lamp/ bracket, front and rear bumpers, 4 tailight housings, lenses, backup housings, lenses, tailgate rubbers, tailgate links, 2 sets rockers, batterybox, upper and lower 4 row core rad mounts, washer container, arm rests, heater vents, 4 speed boot and ring
Also 2 Speed warning speedos, extra temp, amp , gas guages mint inner fenders, rad support, taigate, grill, hood, 2 rock pans. Cab need rockers and cab corners, goodmark cowl induction hood. Buddy bucket seats, new foam, best set of black lap belts/ retracters you'll find, 3 sets black sunvisors. Vac/ tach/ speedwarning dash.high hump/ no hole yet, custom, horn button, 4 speed tilt cluumn, tinted glass
I'm sure I forgot lots, every thing I have NOS, I have from the original truck in good shape,...best offer!
Robert Paul Thomas is offline   Reply With Quote
Old 10-11-2008, 06:32 AM   #2
Robert Paul Thomas
Re: WIW best of best
Also, I forgot I have almost 2 sets of NOS body trim
Old 10-11-2008, 08:17 AM   #3
olblue60@aol.com
member
what is it that you are selling. NOS parts, or all as a package deal? How much are you asking? Thanks
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 10-11-2008, 09:28 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Any pics?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-11-2008, 09:37 AM   #5
jorgensensc
jorgensensc's Avatar
I would be interested in these pending pics and prices shipped to 77018:
1 set grill hoops
new foam (if it isn't installed on the buddy buckets)
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-11-2008, 09:38 AM   #6
Robert Paul Thomas
Hi guys. Selling the whole lot, won't split up. I do have some pics if you tell me how to upload. Going through some marital issues, and still not resolved. I will try to keep you guys up to speed, as soon as I can
Old 10-11-2008, 09:53 AM   #7
jorgensensc
If you decide to part those parts I asked for (mainly the extra set of grill hoops and the mirrors, I don't really need the foam) then let me know.
Shawn
Old 10-11-2008, 10:32 AM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Try some of these threads on posting pics:
How to Attach pictures to your post...
How to post pictures on this site... (this is what I use)
How to post pictures, step by step instructions, using BB code...
-Nate
Old 10-11-2008, 11:22 AM   #9
Shane
Shane's Avatar
Post prices. Best Offer is not a price and there are rules against auctions. Just a heads up.
Shane is offline   Reply With Quote
Old 10-11-2008, 12:16 PM   #10
fine69
fine69's Avatar
All parts must have prices per board rules.
Please change it.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 10-11-2008, 12:36 PM   #11
Looks like a WIW thread.I moved it to where it belongs.
When you do decide to sell,it will need to have a price on the lot.
I`d give my best estimate,but would like more info and,yes,pictures would help.You will get less as a packege than selling the truck and parts seperately.I`d at least sell the truck seperate from the parts as alot.But,selling parts seperately would bring the most money.Good parts ell themselves.It`s not that much effort.
Old 10-11-2008, 05:53 PM   #12
Robert Paul Thomas
Sorry, guys, first time seller. I did know of the price part, that is why I thought I could post under WIW. I also have two sets of NOS outer door handles, inner door handles, and window cranks, center A/C vent, not sure what else. I will post pics tomorrow. almost 30,000 invested looking for 20,000
Old 10-11-2008, 07:08 PM   #13
streetstar
streetstar's Avatar
is this an assembled , painted and running truck with a trailer full of parts to go with it? or is it a rolling chassis and a trailer full of parts?
Sounds like a lot of good stuff -- i would guess 20k if the truck was assembled and ready to go with presentable paint.
If its not, then it sounds like a high dollar basket case and i have no idea how to price something like that
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 10-12-2008, 09:14 AM   #14
Robert Paul Thomas
I have to agree with street star, but honestly, I have closer to 40 in this truck. Chassis is a roller finished, rest is in parts. Some on=ther stuff I forgot ECE front sway bar, ECE close ratio steeringbox, NOS window reg, 5 clutch/brake pads, with the stainless trim, gas pedal with ss trim studs, door lock knobs,.....
Old 10-12-2008, 04:59 PM   #15
fine69
fine69's Avatar
Pics would do this thread wonders.
Board member #6
Old 10-13-2008, 05:07 PM   #16
Hart_Rod
Hart_Rod's Avatar
Email me the pics at robhartley@aol.com and I will size and post them for you.
R
Hart_Rod is offline   Reply With Quote
