Old 10-11-2008, 10:20 PM   #1
harrdawg54
harrdawg54's Avatar
Camaro Fan Install
With inspiration from thishttp://67-72chevytrucks.com/vboard/s...ad.php?t=50085
thread, I thought I would try to tackle my version of an electric fan install.
I purchased a dual electric fan setup from a '9X camaro at a local parts yard for $75.00 and some angle aluminum for $35.00. I am in the middle of doing a motor, transmission and transfercase swap so I already had my front clip off. When I started it looked like this.
I then cut up some of the aluminum and made the bottom bracket. This was the easy part, as I had never done anything with any type of metal before. When I was done with that it looked like this:
I then started on the top bracket. I mocked up a few different things and finally decided to do a kind of half box to make it look "pretty". After some cutting, grinding, sanding, drilling and more grinding I ended up with this.
And this is the finished product:
I was pretty lucky and found a brand new Be Cool 75117 Dual Electric Fan Wiring Kit (195 on 175 off) on eBay for $79.00 shipped. This kit sells for $149.95 at summitracing.
So once I get that I will wire everything up and be good to go. If I did my math right I am in it for a total of $189.00, which I think is a pretty good price for the full setup. Thanks to this site for all the knowledge and support, I am a total noob and milk this site for all it's worth.
P.S.> I will post everything about my swap in a build tread once I get it in and fire it up.
1969 Chevy K20 Custom Camper
350, 4sp, 33's
High on plans, Low on funds
harrdawg54 is offline   Reply With Quote
Old 10-11-2008, 10:27 PM   #2
vectorit
What?
vectorit's Avatar
Re: Camaro Fan Install
Nice work area! Where in ID are you? CDA?
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 10-11-2008, 10:40 PM   #3
harrdawg54
harrdawg54's Avatar
Yes sir.....but my truck is in Sagle. I live in a tri-plex and have no where to work on it so I am doing all of my work at my in laws place.
350, 4sp, 33's
Old 10-12-2008, 12:33 AM   #4
Boog
laying low
Boog's Avatar
That looks good. Ought to cool it just fine. I like the total cost too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
