Old 10-12-2008, 01:16 PM   #1
SCOTI
SCOTI's Avatar
Pre-65 vs. Post-65 Rear End ?'s
I know some 64 & earlier trucks use a 'drop-out' style pumpkin like a F**d 9" vs. the 65 & later salsbury (sp?) style that requires the gears to be set-up internally within the housing. What does it take to get the 5-lug pattern on a 64 w/o swapping to a later housing?
I've found differing info. Since it's the weekend, I can't confirm by calling manufacturers so I thought I might check w/some of the board members & see what they've done.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-12-2008, 01:52 PM   #2
Rogue 64
Ol' Blue Viking
Re: Pre-65 vs. Post-65 Rear End ?'s
I replaced my original low geared rearend with a 1968 low milage 3.73 posi.
It is identical except for the panhard rod mount.
I have since had my axles drilled to 5on5.
That was easy!
Driving Paw-paws truck into the Sunset!
Rogue 64 is offline   Reply With Quote
Old 10-12-2008, 08:04 PM   #3
83burban
60-62 had a drop-out center
63-64 had 12 bolts with welded pan-hard bar mount and 17 spline axles
65-66 had 12 bolts with forged pan-`hard mounts (housing) and 30 spline axles
If you go aftermarket you will need to get spider gears for an earlier housing either from a junkyard to aftermarket. Also, 63 housing had backing plates pressed on so to get disc brakes you would have to weld caliper mounts on instead of bolting them on...just some fyi
83burban is offline   Reply With Quote
Old 10-12-2008, 11:36 PM   #4
SCOTI
SCOTI's Avatar
My buddy looked under the bed & said it had a 12-bolt cover so I'm guessing it's the 12-bolt w/17-spline axles.
CPP sells a kit w/30-spline axles, drums, spider gears, gasket, & .500" studs for $500 but we'll prob snag a 68 rear 12-bolt & swap in aftermarket axles w/some local parts house 71-72 drums.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-13-2008, 12:36 AM   #5
olsofti
olsofti's Avatar
I just redrilled my '64.Had to weld up one hole,turn down the axle hub,and used new '71 up drums from the parts store.
Unless I'm mistaken the '67 up rear end is 1 1/2" wider than a '66 down,if that matters to you.
My mistake,you are right.The 2wd 5 lug rearends are the wider ones.
olsofti is offline   Reply With Quote
Old 10-13-2008, 12:40 AM   #6
SCOTI
SCOTI's Avatar
From what I know, the 'late' 70 year model thru 72's are the wider rear housing. Early 70 model & before are the narrower housing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-13-2008, 01:15 AM   #7
Rogue 64
Ol' Blue Viking
My 68 rear is the same width as a 64.
72 disk axles will not fit, I tried.
Old 10-13-2008, 08:08 AM   #8
jason65
Registerd User
jason65's Avatar
CPP has the axles you want. You just slide them in and they come with the drums you'll need. Classic peformance products Is what it stand for. I think.
jason65 is offline   Reply With Quote
