Old 10-12-2008, 11:11 PM   #1
69ChevyRazorback
help with gas tanks that will fit in the rear
Just wondering if anyone knew of any model and makes of different vehicle gas tanks that will work for mounting in the rear underneath the frame. I was told that ford rangers had gas tanks that fit well. just wanting some suggestions that I could find in a salvage yard. thanks
69ChevyRazorback is offline   Reply With Quote
Old 10-13-2008, 08:34 AM   #2
68_chop_top
68_chop_top's Avatar
Re: help with gas tanks that will fit in the rear
Any 68-72 blazer or suburban will fit. You will loose your spare tire. Be careful which tank you choose because the sending unit must be capatible with your gas gauge.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 10-13-2008, 11:20 AM   #3
Myself
I put an S10 Blazer tank in my wife's '68. 20 gallon and the sender works with the factory guage. But, I had to notch the frame rails a little on each side. A friend of mine has a Bronco II tank in his and it fits real nice. He bought his sending unit through a local street rod builder.
Myself is offline   Reply With Quote
Old 10-13-2008, 12:18 PM   #4
Brad
Out of the carpool lane.
Brad's Avatar
I've used a '73 Suburban tank, but it does stick out past the frame rails and you'll need to build a frame of some sort in order to protect it against a rearend-er.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 10-13-2008, 12:31 PM   #5
BP68
BP68's Avatar
I have a 72 Blazer tank in my 68's rear frame rails. Fits great.
68 C10 Shortbed Fleetside
06 Chevy Ext Cab Fleetside
03 Grand Prix GTP
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999
BP68 is offline   Reply With Quote
Old 10-13-2008, 01:17 PM   #6
68chevy68
68chevy68's Avatar
I too just used a stock blazer tank. LMC has a kit that comes with the sending unit, straps and bolts to just bolt it in. Mine went in with no problem. You will have to modify one of the braces on the bed for it to fit and figure out where you want the filler to be.
68chevy68 is offline   Reply With Quote
Old 10-13-2008, 01:54 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Any of the BB vendors will carry that same Blazer/'burb kit.It might even be a little cheaper thru them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-13-2008, 08:16 PM   #8
woodwright
Enjoying left field
woodwright's Avatar
I've got a 90 Isuzu trooper tank. Its a nice it but the sender is gonna be interesting. I'm switching to all aftermarket guages so I don't think it will be a problem.
woodwright is offline   Reply With Quote
Old 10-13-2008, 11:48 PM   #9
69ChevyRazorback
will you have to buy a new/longer fuel line to in order for the rear mount kit from LMC to work??? just wondering what other items I need that dont come with the kit.... maybe an example of how some of you guys have installed it would help. thanks for the feedback!
Old 10-14-2008, 07:06 AM   #10
70GMCer
70GMCer's Avatar
Here's some info from the FAQ.
http://www.67-72chevytrucks.com/vboa...d.php?t=212828
http://www.67-72chevytrucks.com/vboa...d.php?t=234732
http://67-72chevytrucks.com/vboard/s...ad.php?t=74876
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
