10-12-2008, 11:50 PM | #1 |
6.0 powered square
how low does my truck look
I realy don't under stand,I lowerd my truck back in march and I orderd djm 3inch drop spindles 2inch djm drop coils and a beltec flip kit from summit but the front only looks like, its only been lowerd 3 1/2 to 4 inchs so i'm thinking the springs are heavy duty srings and the stance is really buging me, so how much lower would have to go to have the top of the rim to wheel well be the same front and back.
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
10-13-2008, 08:17 AM | #2 |
Re: how low does my truck look
well, heres the thing. the front and rear wheel well opening are different heights. if you want them to be at the same height your going to have a slight rake.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!! |
10-13-2008, 08:38 AM | #3 |
6.0 powered square
that what I want
10-13-2008, 08:58 AM | #4 |
dang its hot
check your clearances and be aware of your topography and if you can go lower, start with half a coil on the front,
10-13-2008, 10:38 PM | #5 |
I don't think these pills work
mine is a 4/6 and it sits like that the back tires tuck but the front there is about a 1 inch gap. but if you measure or stand back and look the front is actually lower, but my tires are smaller on the front than the back.
SQUARE84 90 SUBURBAN |
10-14-2008, 01:24 AM | #6 |
Garage Queen Material
mines the same way with 4.5" drop in the front and a rear flip kit.
i hate it, the front looks so much higher. but... if you step back 20+ feet, it looks perfect |
10-14-2008, 02:15 AM | #7 |
67-72 parts collector,…
Start cutting the coils. 1/2 coil = approximately 1 inch of drop.
10-14-2008, 02:42 PM | #8 |
Until Seventy Times Seven
I'm guessing in the neighborhood of 2 1/2". Measure the vertical distance between the rim and the fender lip on the front and rear for a more accurate calculation. You'll 'bably end up with at least a 2" rake. It may be challenging to accomplish this by cutting enough coils off of a drop coil without causing alignment, clearance and ride issues. It may be Dropmember time.
Sumin' like this:
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
10-14-2008, 06:51 PM | #9 |
Slugish
Yea ,I see what you mean . according to your specs you should be 5 in. in the front & approx 6 in the rear - Iagree the rear looks perfect (in my old fart opionion) My 84 is 5.5 in in front (2.5 spindles & 3 in drop coils from Eibach)Sorry dont have pic. but mine tucks very well , & yours should to// theres only 1/2 in difference in yours & mine . Are The coils seated into the pockets well -- Im sure they are , but your truck should be lower than that in front with a 5 in drop. ????
10-14-2008, 08:41 PM | #10 |
6.0 powered square
thanks for the info everyone and thanks for the photo shop boxrods
in the future I might bag it, but fo now I'll cut a coil off
10-14-2008, 08:43 PM | #11 |
6.0 powered square
here is what my truck looked with 2'' drop shackles
10-14-2008, 09:01 PM | #12 |
It looks like a 4/6 drop from the pics. What size are your F/R tires? Mine has 3" spindles + 1-coil cut & a flip-kit + shackles . .....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-14-2008 at 09:03 PM. |
10-14-2008, 09:27 PM | #13 |
6.0 powered square
front 215-70 26.9
back 275-60 28
10-14-2008, 09:34 PM | #14 |
My tires are a little taller 215-75-15's. Check these measurements against your truck.
Front.....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-14-2008 at 09:39 PM. |
10-14-2008, 09:38 PM | #15 |
Rear w/255-70-15's.....
10-14-2008, 09:44 PM | #16 |
6.0 powered square
mines 26 1/2 from were yours is 25 5/16
and the rear is 25
10-14-2008, 09:52 PM | #17 |
6.0 powered square
here the back of mine
here is when I had the drop shackle
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 10-14-2008 at 09:54 PM. |
10-14-2008, 10:24 PM | #18 |
flamingbig10,... another coil removed, is going to drop it 2 inches more. Correct alignment will not be easy,... if at all possible.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-14-2008 at 10:25 PM. |
10-14-2008, 11:28 PM | #19 |
6.0 powered square
oops I ment a half a coil
