Old 10-15-2008, 10:52 PM   #1
tommys66
reproduction steel doors or fiberglass?
I am having trouble finding a set of good oem doors. From southeast missouri and everything around here is rusted out. Would be willing to drive for a good set though. Just wondering if anyone has used the repo steel or fiberglass doors. Curious if they fit well or not. Thanks for any input.
tommys66 is offline   Reply With Quote
Old 10-15-2008, 11:27 PM   #2
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: reproduction steel doors or fiberglass?
Check out my build link it will show what I went thru. I used Goodmark doors. I don't know which company actually made them for Goodmark. Over all I'm pleased with the overall fit. I did have to do some cutting only on the top front edge of the drivers door.
They are a little wavy.
Alan's Classic is offline   Reply With Quote
Old 10-16-2008, 10:39 AM   #3
MEANlowGREEN
Registered Asphalt Offender
MEANlowGREEN's Avatar
Yep, the Goodmark doors will require a little tweaking like Alan showed you but that goes for any aftermarket sheet metal. They are high quality parts though. I would always go steel if it's available. Unless you are building a racer and need it to be light weight.
It's not too low unless the tires won't reach the ground anymore!
1963 C10 Short Fleetside Bed Big Back Glass
1974 C10 Short Stepside Bed
1982 S10 Shortbed 350 EFI V8
http://67-72chevytrucks.com/vboard/a...hp?albumid=140
http://www.hubgarage.com/mygarage/MEANlowGREEN
http://www.motortopia.com/garage/cars/MEANlowGREEN
http://www.myspace.com/jcsmeed
MEANlowGREEN is offline   Reply With Quote
Old 10-16-2008, 11:19 AM   #4
skidder111
skidder111's Avatar
Personally I would go thru the heartache of rebuilding the originals over another set of Goodmarks. There are definite differences/flaws compared to the originals. I got them to work, but..........Maybe I'm just too fussy.BTW this was on a '72.
skidder111 is offline   Reply With Quote
Old 10-16-2008, 06:41 PM   #5
Alan's Classic
I know the 67-72 Goodmark doors have alot of issues. Two coworkers replaced both of their doors on both trucks and had alot of problems.
Old 10-16-2008, 08:43 PM   #6
tommys66
good lookin cab. I see you have shaved the drip rails on the posts, is this why you had to add the piece to the door?
Old 10-16-2008, 09:09 PM   #7
Alan's Classic
I thought that was the cause, but the passenger side lined up pretty good.
Old 10-16-2008, 11:20 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
A little off topic, but here goes anyway. I bought a re-pop fender for my pick-up and thought it sucked. I took out the piece from behind the grill and replaced it w/ the original and figured I had about 3 hours work on a 'new' piece of sheetmetal. I just picked up a fender for my 'burb that is good but has some dents and needs the typical lower patch. I think I can get it done in a few hours time, improve my skills, and come out at least 100 bucks ahead of the re-pop fender. Luckily there are tons of good parts here in AZ.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 10-18-2008, 12:08 PM   #9
mbgmike
The 64-66 doors fit better than the 67-72 and Goodmark quit selling them. We also do not sell the 67-72 doors currently. We have not had too much trouble with the 64-66 repro doors. Even the stock doors from truck to truck are not perfect fits. I went through 4 oem doors on the drivers side door and never really found one that did not leave a large gap on the A pillar. I the passenger sides was fine.
mbgmike is offline   Reply With Quote
Old 10-18-2008, 12:11 PM   #10
mbgmike
This is pretty typical with these years. If you take off the drip rail. I do not really have a clue why but the passenger side always comes out better as far as gaps
