Old 10-19-2008, 08:18 PM   #1
zeusflash
zeusflash's Avatar
WTB Speedometer ratio box
My 72 GMC 3/4 ton 4x4 is missing the speedometer ratio box. The gear ratio in my truck is 4.56. Any help will be greatly appreciated. Thanks in advance.
'69 3/4 ton 427 CST Pickup
'71 CST Blazer
'72 GMC 3/4 4x4
zeusflash is offline   Reply With Quote
Old 10-19-2008, 09:39 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: WTB Speedometer ratio box
How far is it off? I have a few laying around and would part with one if it would work for you. Go down the road for 5 - 10 miles and match your odometer against the mileage markers.
Get the correction ratio and post it here.
low'n slow is offline   Reply With Quote
Old 10-20-2008, 08:13 AM   #3
va_tlc
va_tlc's Avatar
low and slow, is this the little metal looking box that the speedometer line screws into to? if so after zeusflash is taken care of , i need one for a 3.73 auto truck, thanks alot.thanks alot.
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 10-20-2008, 08:31 PM   #4
zeusflash
zeusflash's Avatar
va_tic,what I need is the little metal box that attaches to the transfer case and the speedo cable attaches to. On 4x4s there was only one speedo drive gear available in the transfercase so the ratio box is used to syncronize the drive gear to the speedometer head for different gear ratios. The ratio box has two gears in it to either speed up or slow down the speedo cable as needed. As to how much mine off....the box is missing completely!
'71 CST Blazer
'72 GMC 3/4 4x4
Old 10-20-2008, 09:14 PM   #5
low'n slow
low'n slow's Avatar
Still need to know the ratio of correction. I have 4 of them.
Old 10-20-2008, 09:34 PM   #6
zeusflash
zeusflash's Avatar
Sorry low'n slow, I didn't understand what you were asking for. Probably will not get a chance to do this until next weekend...I still have to change the speedo cable.
'71 CST Blazer
'72 GMC 3/4 4x4
Old 10-21-2008, 07:45 AM   #7
va_tlc
va_tlc's Avatar
mines not even on the road yet, but mine is leaking gear oil outa it, thats kinda why i wanted one.so if you do have a extra one after zueusflash, keep me in mind thanks
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
Old 10-26-2008, 07:20 PM   #8
zeusflash
zeusflash's Avatar
Did the road test yesterday,had my wife pace me in her Suburban,did the math and it didn't seem right. I installed a ratio box I had laying around(1.202 ratio). Redid the pace test,did the math an got the same answer. Looks like I need a ratio box right around .877. Let me know what you come up with.
'71 CST Blazer
'72 GMC 3/4 4x4
Old 10-26-2008, 08:53 PM   #9
low'n slow
low'n slow's Avatar
I have 1 that is 1:0.9, should slow it down almost 10%. That is about as close as I can come. PM me if you want it.
Old 10-26-2008, 08:58 PM   #10
msgross
msgross's Avatar
if you know someone that has a GPS you can use the speedo on it as well...
Tire size will change your ratio as well...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
