Old 10-20-2008, 10:49 AM   #1
mbc9ieII
changing a truck from a 3 speed to an Automatic
do i need a different crossmember for the tanny?
or can i use the same one that i have for the # speed... one mount in that back?
mbc9ieII is offline   Reply With Quote
Old 10-20-2008, 10:55 AM   #2
cdowns
cdowns's Avatar
Re: changing a truck from a 3 speed to an Automatic
you need to remove the crossmember that is under the engiine/bellhousing and you'll also need an automatic tranny crossmember to go under the tailshaft of the tranny
Old 10-20-2008, 12:04 PM   #3
my70chevyc10
my70chevyc10's Avatar
You need a different trans mount and a different starter the starter for the manual trans mounts to the bellhousing. The one you need for the automatic mounts to the engine block with a stright across bolt pattern or a staggered one. The auto crossmember has 2 small peaces on the ends that has to fit between the frame. I just drilled out the rivets an used only the bottem part of the crossmember my trans guy said it is strong enough.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline   Reply With Quote
