Oil pan gasket, please help!!!
Hey guys I have a 70 blazer with a 350/465 and I noticed a drip forming from what appeared to be the front main seal on my oil pan and decided that i would go ahead and install a new 1 pc gasket. As it turns out I am having a really difficult time removing the oil pan because of the engine crossmember. I have removed the engine mount bolts and jacked the engine enough to put scrap 2x4 pieces between the mounts and crossmember and dropped the oil pump down into the pan so it can move more freely but still no luck... Please tell me i don't have to pull the engine to get this thing out. -Tristan
Active Member
![]() Join Date: Jul 2007
Re: Oil pan gasket, please help!!!
Did you try turning the crank to see if you can get some clearance. It's been a long time for me but I do remember having some trouble also. I also remember turning the crank and getting some clearance.
Anyway, here's a bump in case someone's done it recently. |
72 chevys 4 life
hmm if its like my 72 c10 they are just the funnest thing to do...its just that front seal that goes in your timing chain cover?? if so you dont even have to pull the oil pan...but it does make it easier to get that timing chain cover off. To get the oil pan off prob jack it up about as high as you can get it that is what i did and undo the tranny mounting bolts also dont wanna twist something too bad
I dont call it being young and dumb....I call it young and havin fun ![]() |
Oh ok, that sounds like it might do the trick, I'll give it a shot. Thanks
Not only that but if you got the same blue one piece I got, it will not fit your pan. Mine leaked like a seive until I put the stock pan gasket back in.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Be careful when you jack the engine that you don't break the distributor cap when it hits the firewall.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
When I did mine I had to remove the crossmember. It only took me about 3 hrs total.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
This was my first thought also. to be on the safe side I would remove it. especially if your running a H.E.I. distributor.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
72 chevys 4 life
mine didnt have to get that high to hit the distributor but good thinkin
Yep....front, side everywhere. It was basically too thick all around but more so in the front for sure. I guess he got the wrong one.
1997 GMC Sierra Ext 1965 Mustang |
