Old 10-22-2008, 02:15 AM   #1
Ford Assassin
Ford Assassin's Avatar
Question How hard is it to swap in a 14 bolt?
Hey guys. Right now my stock '69 C10 has its original 12 bolt with 3.08 gears and peg-leg open diff. I was planning on swapping to 3.73 gears and adding a posi when I started thinking maybe I should just swap in a 9.5" 14 bolt instead.
When I still had my K5 I blew the 12 bolt all over the trail and swapped in a 14 bolt with ease and never had a hint of trouble with it afterward. However that was with a leaf spring rear suspension, not a trailing arms suspension like my current truck.
I am also interested in the swap because I also plan on towing an RV in the near future and don't want to worry about strength issues with my stock 40 year old 12 bolt.
I know where I could score a low mileage 9.5" 14 bolt complete with brakes, 6 lug axles, 3.73 gears, and posi for less than $100. Which would be hundreds (if not a thousand) less than rebuilding my 12 bolt.
My question is how hard would it be to swap in with my trailing arm rear suspension?
I am sure some of you have done this to your trucks, so lay it on me, what's involved?
Thanks guys!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 10-22-2008, 11:43 AM   #2
umwtnt
umwtnt's Avatar
Re: How hard is it to swap in a 14 bolt?
I have not done this swap but, just thinking about it, it should be fairly simple. I would check width of the 14 bolt first to ensure no fitting issues. Cut off the spring mount pads, purchase a new set of mounts, center the diff in the frame and mount everything. Don't forget to check your pinion angle before welding up your mounts. Of course before tighting or welding set everything at ride height to insure all is correct. Connect your brakes lines, E-brake cables and drive shaft and enjoy. I do not believe it would be much harder then the other differential swap you performed. Good luck and enjoy. Oh yeah, you may have to get a panhard kit from someone like ECE to keep the diff centered.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 10-22-2008, 12:44 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Heres where you can pick up new mounts and U bolts but you will need an axle mount for the panhard bar.
http://www.stockcarproducts.com/trkarm1.htm
sneakysnake is offline   Reply With Quote
Old 10-22-2008, 12:57 PM   #4
Ford Assassin
Thanks guys, I have the top end panhard bar from ECE, so no worries there.
The link you posted is for 3" tubes, the 14 bolt has 3.5" tubes.....
Cable
Old 10-22-2008, 01:10 PM   #5
sneakysnake
Opps, might as well just cut the ones off an old axle,then they would be about 3.5".
Old 10-22-2008, 01:44 PM   #6
sneakysnake
The axle width will probably screw up the U bolt from lining up with the trailing arm holes
Old 10-22-2008, 03:12 PM   #7
chevy72blu
chevy72blu's Avatar
Sorry - I dont have any experience with this swap.
But, why not just convert to leaf springs in the process? Seems like it would simply things a bit.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 10-22-2008, 06:46 PM   #8
Ford Assassin
Talking Re: How hard is it to swap in a 14 bolt?
I should of posted this in my initial post, I am not interested in swapping to a leaf spring setup. I already have a Air Lift adjustable airbag setup along with new shocks, adjustable pan hard bar, trailing arm bushings, etc. Plus I like the nice and smooth ride the trailing arm setup gives me when cruising.
Cable
