10-22-2008, 03:04 PM | #1 |
1986 c-10 surging problem , please help
I have a 1986 c-10 silverado with a computer controled carb. I had the carb and transmission rebuilt a year ago and engine rebuilt 3 years ago. Recently it has been surging once up to speed after it is in 3rd gear.It feels like maybe the timing is being retarded or something , it runs good for about 3 seconds then bad for 3 seconds, it also has a strong fuel smell when it is surging but I cannot find any fuel leaking any where not sure if it would be the map sensor or maybe something came loose inside the carb ? Any help would be geatly appriciated
10-22-2008, 09:43 PM | #2 |
Robert Olson Transport
Re: 1986 c-10 surging problem , please help
does it have a check engine light on?? even if it doesnt you can have the codes pulled usually for free at like autozone and that should tell you if its a sensor..
welcome to the board by the way and when ya have time post some pics!
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 10-22-2008 at 09:43 PM. |
10-23-2008, 06:23 AM | #3 |
The check engine light is not on , however some time ago it came on with a code 34 which was the MAP sensor because the wires to the sensor were touching each other , I fixed the wires and the light went out , but was wondering that maybee since the wires were touching it may have damaged the sensor. I will post some pics when I get a chance , however it could use a paint job it has original paint
10-23-2008, 06:45 AM | #4 |
dang its hot
you could have dirt in the carb causing the float to stick, flooding over. (or leaning out) next time it does it, pullover and yank the air cleaner off(engine not running), see if the carb is dripping fuel into the intake. If it isn't, pump the throttle with your hand and look into carb for a pump shot, if nothing, float may be stuck closed. Now there may be other things like the sock on the fuel pick up in the tank dirty and colapsing, dual tanks? does switching tanks effect it? Is the fuel pump leaking out the weep hole? does the oil smell gassy? I dont think it's ignition. Can you floor the throttle and it comes out of it? Does it fall on its face when you floor it when this condition happens? these are indicators of rich or lean conditions. I'd bet its flooding over if I were a betting man.
10-23-2008, 09:31 AM | #5 |
autozone will not let you borrow their diagnostic tools anymore. Some lawsuit i guess. You have to buy the tool to use it.
10-23-2008, 09:41 AM | #6 |
Georgia Boy
AZs tools can only read OBD II systems now anyway.. but I'm with grinch, sounds like a carb problem. See if you can borrow a older carb from a friend and try it.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
10-23-2008, 03:55 PM | #7 | |
