Old 10-22-2008, 07:30 PM   #1
munchieu
Zn' the frame
Why? What does this do? Does it need to be done to get the truck to lay frame? Anyone here do a step by step with pics thread? i think i have an idea. just want to se some shots
munchieu is offline   Reply With Quote
Old 10-22-2008, 07:56 PM   #2
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: Zn' the frame
Yes it has to be done to lay frame. The front supension and crossmember hang below the frame. The Z raises it so the frame is the lowest point. Look through the suspension section to find pics. Here are a few of the Z i had on my 69. This one wasn't finished. I also put a plate on the inside of the frame after this pic was taken. The second shows how the steering needs to be modified.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 10-22-2008, 09:34 PM   #3
leftcoast66
leftcoast66's Avatar
Re: Zn' the frame
Yep, 69 had it right. To lay it'll need to be atleast 2 and at max 4 inches. But you can throw down and go big on a dropmember to get it out of the way, but there aren't any other alternatives.
leftcoast66 is offline   Reply With Quote
Old 10-24-2008, 07:45 PM   #4
munchieu
Re: Zn' the frame
What about Zn the rear. Is there a max? Also if i Z the rear, then i should not need to c-notch it or build new back half right?
Old 10-24-2008, 09:17 PM   #5
shortbed70
shortbed70's Avatar
Re: Zn' the frame
Back is a different story you will have to raise the bed floor or be gone with it and its simpler to put a big notch in. I look at it this way if your going to z the rear just cut it off and back half the truck its the same amount of work. Do a search in the suspension forum you'll find endless amount of info.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-24-2008, 09:29 PM   #6
PrerunnerRob
PrerunnerRob's Avatar
Re: Zn' the frame
I z'd mine at first, and the distance you have to start at to clear the stock trailing arms is not worth it in my opinion. You have to start right behind the cab, I came up at a 45 degree angle with a new frame clip, and I wish I had just put in a notch with a new 4-link.
Dont forget you have to rebuild/modify the trailing arm crossmember!
PrerunnerRob is offline   Reply With Quote
Old 10-24-2008, 09:52 PM   #7
SCOTI
SCOTI's Avatar
Re: Zn' the frame
It all depends on the builders goal. Z'n the factory rails can & does work well if you like the bags in the stock coil location. If it's planned well, it simplifies several things.
If you're going to move the bags though, you prob would be better off w/a different suspension or back-half it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-24-2008, 09:55 PM   #8
joe231
joe231's Avatar
Re: Zn' the frame
hey Rob, you dropped a smoke
looks nice
CHEVY ONLY
joe231 is offline   Reply With Quote
