Old 10-22-2008, 11:38 PM   #26
NWD02
Cool Re: Fire wall smoothing
I ordered the Gen II evap kit and billet controls from Vintage Air. I'm going to run the lines through the passenger side fender then in the cab. Haven't figured all the details out yet on the route for the lines. With the Gen II kit the coil lines go toward the kit panel. The sure fit kits has then going through the firewall, Vintage Air told me they could change it but to add $150 to the kit. I kindly responded with a "No thanks." The Gen II kit also uses servo motors, not the old school cables which I was told it works a lot better.
http://www.vintageair.com/08/catalog...g%2016%20f.pdf
Top billet controls:
http://www.vintageair.com/08/catalog...g%2027%20f.pdf
total so far:
evap and billet controls plus shipping total $699.... 94 chevy truck compressor new from oreilly's $150....
parts still needed:
lines, dryer, condenssor, billet vent from jegs.... i think this is it
NWD02 is offline   Reply With Quote
Old 10-23-2008, 01:09 PM   #27
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by tommypic View Post
I would like to see some pics of the wire routing . I have mine shaved but not the fuse box connector , like some I have seen . I will get some pics up so yall can give me some ideas on what else to take off
Just run the wires on the inside of the cab... easy peezy....
lyrikz is offline   Reply With Quote
Old 10-23-2008, 01:11 PM   #28
lyrikz
PITbut
lyrikz's Avatar
How do you grind smooth the area between the firwall and the channel....
What do you use in there???
Old 10-23-2008, 01:40 PM   #29
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If you smooth the firewall to the extent that some have, an aftermarket unit is going to be necessary for heat and ac. Bringing the passenger side out so the contour matches the drivers side shows me that the blower motor squirrel cage fan isn't going to be used any more. With the cutouts still being there for the heater core and the ac evaporator, kinda makes me wonder what their plans are.
The latest edition of Custom Classic Trucks magazine has an article on stretching/shrinking metal, with Dakato Wentz actually creating the metal that he needed to get rid of the trough that we all know and love to hate. The article is actually oriented towards learning to use the stretching and shrinking tools. You can get the tools at Harbor Freight as well as Eastwood. I believe the tools are the same at both locations.....and made in China. But, I've seen them used and they will get the job done.
Covering that trough is about as far as I can go in smoothing my firewall, but I think I wanna go for it.
Member Nr. 2770
Old 10-23-2008, 01:54 PM   #30
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Originally Posted by cstm68 View Post
what are you guys using for a heater?
I am using a Yale electric fork truck heater......Works pretty good for my needs..........
bad6772 is offline   Reply With Quote
Old 10-23-2008, 02:37 PM   #31
ColoradoK5
ColoradoK5's Avatar
I just got a heater only from Vintage Air. i have to figure out wher/how i am going to mount but my friend had one in his hot rod worked a little 2 good
ColoradoK5 is offline   Reply With Quote
Old 10-23-2008, 02:42 PM   #32
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by lyrikz View Post
How do you grind smooth the area between the firwall and the channel... What do you use in there???
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-23-2008, 03:12 PM   #33
danman987123
danman987123's Avatar
i like this talk....lol....i just got in my panels from infanti rides to fill in the holes. one of them is a little to big though the odd shaped one that is on the left of the firewall if your looking from under the hood. so i will prolly have to cut that part out of the firewall and make it fit myself. all of the other fillers i got from him seem to fit nice. it also looks like a coulple of trucks on here have the same paint as on my truck or atleast very similar. My truck is sonic blue. thanks again guys for all the input.
danman987123 is offline   Reply With Quote
Old 11-05-2008, 09:55 PM   #34
billdo
billdo's Avatar
did you guys weld it solid on the side of the strip closes to the cab that must be hard to clean the weld cause its a 90 degree what did you guys doooooo.
billdo is offline   Reply With Quote
Old 11-05-2008, 10:14 PM   #35
68 short step
what i used was a cuttoff wheel....to get the 'rough' shape, then hit it with a 2" 80grit in a high speed.
68 short step is offline   Reply With Quote
Old 11-05-2008, 11:08 PM   #36
SCOTI
SCOTI's Avatar
That's how I did mine as well. A cut-off wheel for the basic shape & a small 3M rol-loc disc to smooth it out as much as possible. One quick swipe of filler(after epoxy sealing) & it's a smooth/rounded 90° transition.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-06-2008, 01:32 AM   #37
VA72C10
VA72C10
VA72C10's Avatar
Great info here!
Old 11-06-2008, 09:47 AM   #38
billdo
billdo's Avatar
cool i think i may just tig it idk yet it will tak longer to weld but clean up will be easier
Old 11-06-2008, 12:26 PM   #39
SCOTI
SCOTI's Avatar
Definitely easier to 'clean up'.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-06-2008, 12:47 PM   #40
8mpg
8mpg's Avatar
great thread...Im going to cut the lip off the channel..sounds way easier.
8mpg is offline   Reply With Quote
Old 11-06-2008, 12:59 PM   #41
big_al_71
big_al_71's Avatar
The one thing that I did not that now I am regretting was not having that lip on the firewall smoothed also. I am happy about how it all turned out the way I ran the wires, the a/c hoses but man oh man the more I look at some of the firewalls with the top lip gone the more I am kicking my self for not paying attention. I am glad that I was able to have the curve on the passenger side match the drivers side. I guess my next truck will also have that lip removed...
great information being shared.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
