10-24-2008, 09:20 PM | #1 |
electric fans
Who makes the best bolt on electric fan set up? got any pics
10-24-2008, 09:39 PM | #2 |
Re: electric fans
"flexalite"
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-24-2008, 10:25 PM | #3 |
Re: electric fans
thank you for posting i am installing a billet specialtis tru trac on a 454 in a 68 and am thinking of switchng to electric fans Joe
10-24-2008, 10:34 PM | #4 |
Re: electric fans
I used the BS True Trac and a Spal fan, and a shroud from this place check his store, nice stuff.
10-25-2008, 04:56 AM | #5 |
Re: electric fans
I designed and built my own. Bought the parts on ebay. Cheaper and looks good. (in my opinion, for what it's worth.) Less than $150.00.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
10-25-2008, 12:42 PM | #6 |
Re: electric fans
I used a set out of an LS1 camaro....pretty much the perfect size.
10-25-2008, 12:49 PM | #7 |
Re: electric fans
Head to a pull-it-yourself junkyard and look for a Ford Taurus with the V6, and pull out the fan. Very low buck, but very reliable and it sucks more air than most aftermarket kits I have seen. I paid for my intake and carb by buying them for $15 bucks from the U-Pullit in Vancouver, WA and turning around and posting them on ebay for $60. I have tested them with a battery and they will take flight from a work bench when you give them 12 volts DC. I also put one in my buddies Nova with a built 400SBC, and once the fan is on you can drop a red shop towel in front of the grille about 4 feet away, and it will end up getting sucked flat onto the radiator.
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, 700R4, 3.73 gears Good judgment comes from experience, and experience, well......that comes from bad judgment. 1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then. |
10-25-2008, 04:53 PM | #8 | |
1970 C10
Re: electric fans
thanks! |
11-01-2008, 12:32 PM | #9 |
Re: electric fans
1994-2001
You will be looking for a V6 Taurus, happy hunting.
11-01-2008, 05:37 PM | #10 |
Re: electric fans
Click the link and you'll find 150 threads that refer to electric fans in some fashion or another.
http://67-72chevytrucks.com/vboard/s...earchid=985273 FYI, found by using our fancy little search function. |
11-02-2008, 10:32 AM | #11 |
Re: electric fans
Heads up - He's talking about a big block, not a small block.
The Flexalite fans, while really nice - won't fit, they're too thick. Derale makes a set that will fit with some trimming of the shroud. Last edited by Ozona; 11-02-2008 at 10:33 AM. |
11-02-2008, 11:21 AM | #12 |
Parts and more parts
Re: electric fans
I am running the SPAL dual 11" fans on my 84 and 91 Silverados. I also have a set for my 68 C-10 when I start to assemble it. They work great, easy to attach. I use the "Mill Strap" aluminum material that every farm, hardware, and lumberyard carries. It is easy to cut, bend and polish for looks. The fans have their own shroud built on them and they have a capacity to cool a serious HP motor.
They are sold in Summit Racing under the "Be Cool" fan line. Last edited by piecesparts; 11-02-2008 at 11:22 AM. |
03-04-2009, 08:48 PM | #13 | |
Re: electric fans
03-04-2009, 08:56 PM | #14 |
Champagne Taste on Beer Budget
Re: electric fans
Yeah I to am in the market for an electric fan for my 6 banger. And with some aftermarket parts such as intake and headers it will need the extra cooling of the electric fan can deliver.
Coming Soon: Project 1970 Country Truck |
03-04-2009, 09:32 PM | #15 |
Junior Member
Re: electric fans
I put the '' mopar fan '' that a lot of us got in my big block shroud ,works great . My 402 is .030 over and 10.50 to 1 comp....
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82 12.39 @111.33 With a 180 shot nos 69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/ email fdelcoglin@hotmail.com |
03-05-2009, 07:23 AM | #16 |
Re: electric fans
That's a really nice fit.
03-05-2009, 01:40 PM | #17 |
Re: electric fans
Part # of that Mopar fan?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
03-05-2009, 07:25 PM | #18 |
Fabricate till you "puke"
Re: electric fans
I am running a pair of 14" Flexs a lites in front of my 383(mounted on a steel shelf.)...keeps her nice & cool. The PAINLESS controls are worth what you pay for them. The controls are on @ 185/off 170.....temp runs tween 175-185 ALL day long, on the HOTTEST days in Illinois Those fans are coolin a 385 horse 383....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
03-05-2009, 10:48 PM | #19 |
Junior Member
Re: electric fans
here is the link for the numbers to the mopar fan http://67-72chevytrucks.com/vboard/s...electric+mopar
03-06-2009, 12:01 AM | #20 |
Re: electric fans
my electric fan came out of a 93ish firebird and with very little mods fit behind my factory small block shroud
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
03-06-2009, 12:03 AM | #21 |
Re: electric fans
flex a lite makes a low profile 5/8 thick set of duals. Very nice kit. They fit my big block just right.
03-06-2009, 02:09 PM | #22 |
Re: electric fans
Thanks for the link...just ordered a fan through moparpart.com. $41 plus shipping. I've got a couple of BBC shrouds laying around and will fit them up!
