Old 10-26-2008, 11:05 AM   #1
gintaras
is it a 4-bolt?
How can I tell if my truck has a 4 bolt block?
it is a '72 out of Cleveland.
I was originally going to do a swap, because this truck and motor only have 68k miles, and I thought it'd be a shame to tear down a motor like that.. but now I am thinking I might do a mild build with a top end kit to increase the output to around 350 hp, 350 tq...
are there any numbers on the block I could get to see if it is a 4-bolt
thanks
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 10-26-2008, 11:09 AM   #2
Cyclone
Cyclone's Avatar
Re: is it a 4-bolt?
There is really only one way to tell, disassemble it. I've seen the same block numbers be 2 & 4 bolt.
Cyclone is offline   Reply With Quote
Old 10-26-2008, 11:24 AM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: is it a 4-bolt?
only one way to tell...drop the pan
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 10-26-2008, 12:37 PM   #4
cdowns
cdowns's Avatar
Re: is it a 4-bolt?
4bolt motors aren't really anything special//if its a 4bolt the only real difference in a mild build like you're doing is that you'd need to buy more bolts
Old 10-27-2008, 06:12 AM   #5
Blazer1970
Blazer1970's Avatar
Re: is it a 4-bolt?
Numbers on the block will not tell you but if it is an original four barrel 350 truck motor from the '69 - '72 era, it will be a 4 bolt main.
Blazer1970 is offline   Reply With Quote
Old 10-27-2008, 06:19 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: is it a 4-bolt?
Not true.
Yeah, it is more likely to be a 4 bolt... but not an automatic either.
I would be more excited to see the 10-20 stamping... a high nickle block is worth way more than 4 bolt IMO.
The reality of it though, you are way better off just getting a late model 5.7 block, for the roller cam alone.
