10-26-2008, 11:00 PM | #51 |
A guy with a truck
Re: Rear bag mounting pics please
I used the 7" version. They are a little bigger than the Slams, but not by much. I don't know how they would do up front- my truck is static front/bagged rear...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
10-27-2008, 08:31 PM | #52 |
65 C10 STEPSIDE 66 C10 3" CHOP CAB 55 BUICK ROADMASTER 07 F150 07 22 Ft FOUR WINNS |
10-27-2008, 09:58 PM | #53 |
http://sportruck.com/events/blood-drag-2008/i32.html Here is the rear setup of my truck
11-23-2008, 01:53 AM | #54 |
Stirrer of the Pot
I forgot about this thread...
anyone else have more pics of bagged rides utilizing the stock trailing arm setup instead of the 4-link and wishbone setups we see more often? |
11-23-2008, 05:12 AM | #55 | |
Keepin it old school
The Dominator 2600s are equivalent to the Slam RE7. Alot of people Use the slam RE7 on all 4 corners so you should be okay. I will be using Dominator 2600s on all four corners. My truck is at the shop right now... |
11-23-2008, 01:35 PM | #56 |
I have doms on mine, between the factory arms and frame, one bolt from the bottom, two from the top-works great
11-23-2008, 03:19 PM | #57 |
When you guys mount the front bags done you weld in the buttom cup or just let it move around??
Thanx Trevor |
11-23-2008, 04:09 PM | #58 |
the lower cups float, or you wouldn't be able to remove the bags later.....
well maybe you could through the hole in the spring pocket
CHEVY ONLY Last edited by joe231; 11-23-2008 at 04:10 PM. |
11-23-2008, 05:37 PM | #59 |
Stirrer of the Pot
my lower cups are welded in and I bolt them through the bottom of the a-arm.
11-23-2008, 06:14 PM | #60 |
Mine floats in there just like the spring did.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
11-23-2008, 11:24 PM | #61 |
GM ONLY BABY!!!
Mine float in the A arm as well. I actually cut 1" off the bottom cup and like it. I will be doing the rear airride install this spring, when I swap my GMC over to a Chevy frame.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
11-24-2008, 12:33 AM | #62 |
Thanx guys. I think I got everything figured out. Got the rear C-notched and bagged, done right this time, and the front all done. Just got to get the air managment system, $$$, then I can bolt all this stuff in place..
11-24-2008, 12:47 PM | #63 |
Stirrer of the Pot
Hey TK- can you post some pics of your new setup? thanks bro-
11-24-2008, 12:59 PM | #64 |
I haven't got it all mounted yet, but specifically what would you like a pic of. I mocked up the rear, just didn't bolt it up.
Let me know whatcha need. Trevor |
11-24-2008, 01:19 PM | #65 |
Stirrer of the Pot
I'd like to see a pic of how how your bags are mounted, how you are running the airline, and how big your notch is...
Sorry for the laundry list... LOL. I'm trying to decide on how wild or mild to do my brother's 62. I have it mocked up for a pretty mild job for now, but am contemplating more. |
11-24-2008, 01:49 PM | #66 |
I posted a pic of the rear in post #47. I haven't run the lines yet, cause I don't have the funds for the air management system I want yet. I have a basic c-notch bolted in with air lift dominators (2600's). The rear diff hits the bed floor before the axle tube hits the c-notch bumpstop, have about 1" before it'll hit. So I will more then likely cut the bed floor out abit..
11-24-2008, 04:13 PM | #67 |
GM ONLY BABY!!!
www.***************** has some good deals.
11-24-2008, 06:34 PM | #68 |
Ya, I know... I want the auto pilot kit.. Spent all my money on powertrain and still not done..
11-25-2008, 07:27 PM | #69 |
I was stoked to find this thread...Im putting bags in this weekend. I also have trail arms (C20) with Dominator's all the way around...Im lookng for a wiring diagram from battery to two compressors...
11-25-2008, 07:56 PM | #70 |
Tonawanda 454
no C-notch here, just some bags on my R2500 that look like they may have been original (or maybe not)...
I think it may be original because there are no springs, it is just leafs and bags... I do know they work well although they are manual fill, no automated air pump...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- Last edited by screwballl; 11-25-2008 at 07:57 PM. |
11-26-2008, 12:27 AM | #71 |
One day...
Yeah i bet they do! looks like you can hold some weight with that setup!
11-26-2008, 11:46 AM | #72 |
here's mine, slam re-7's
11-26-2008, 11:48 AM | #73 |
more.
11-26-2008, 01:28 PM | #74 |
Hey Pocketpool, nice set up. Good pics-thanx.
Trevor Last edited by tk-mpl; 11-26-2008 at 01:28 PM. |
11-26-2008, 06:30 PM | #75 | |
Stirrer of the Pot
I guess I was specifically hoping to see mounting hardware and what not. I did see your other post. It looks like guys are just running a single bolt through the middle of the trailling arm, but I was confused on that because of the "I" shape of the beam. I'm going to play with it tonight and hopefully get these things in and done before Friday. |
