10-28-2008, 11:01 AM | #1 |
Stock Proportioning valve
Heres what I want to use on my 69 step---I converted it to disk front only(from a 85) and I want to use a stock master and booster from the 71 type for disk-drum combo.I can buy the stock type for under $100 but I cannot find a stock type proportioning valve anywhere,anyone actually know where I can buy one? Thanks Chip
10-28-2008, 11:35 AM | #2 |
It's a catastrophic success.
Re: Stock Proportioning valve
If your local parts store dont have one
http://www.inlinetube.com/Prop%20Valves/pro_valves.htm |
10-29-2008, 08:31 AM | #3 |
"THE GREEN GOBLIN"
X2 InlineTube
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
10-29-2008, 08:51 AM | #4 |
IIRC i got mine from ECE: http://www.earlyclassic.com/catalog.aspx
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 10-29-2008 at 08:52 AM. |
10-29-2008, 09:01 AM | #5 | |
Active Member
10-30-2008, 11:42 AM | #6 |
Mike's bump and grind here on the board was the most reasonably priced when I did my drum to disc swap. I di get my lines from inline though.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
10-30-2008, 02:27 PM | #7 |
I tried repeatedly to re-set the prop-valve on my 74 following instructions from here but it wouldn't work so I just got a new one & haven't had a prob since (7-07). I used Inline-Tubes valve & 4pc front stainless hardline kit.
