Old 10-29-2008, 11:13 AM   #1
kulturekat
kulturekat's Avatar
taking out headlight dimmer switch?
i did a search but couldnt find anything on replacing or how to get the dimmer switch out of the dash. i know i unscrewed the bolt holding it in from the front i got it loose but is there a notch or something on the back side that i need to do to get the knob to come out of the unit? i got new gauges and bezels and stuff to replace but cant get the wiper or dimmer switch out to change the stuff. thanks in advance
kulturekat is offline   Reply With Quote
Old 10-29-2008, 11:31 AM   #2
1970heavychevy
busted knuckles
1970heavychevy's Avatar
Re: taking out headlight dimmer switch?
The dimmer switch or the light switch? The light switch to the left of the steering wheel has a button top. Push it and pull the knob out. Then unscrew the bezel and nut holding it in. The wiper knob is just a bezel and nut holding it in place.
1970heavychevy is offline   Reply With Quote
Old 10-29-2008, 11:36 AM   #3
kulturekat
kulturekat's Avatar
perfect thank you ill try that when i get home
Old 10-29-2008, 12:12 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Pull the knob out first, then press the button on top, and pull the rest of the way. Might want to disconnect the battery ground first cause your lights will go on.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-29-2008, 01:00 PM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Here's what your feeling for.LOL
sneakysnake is offline   Reply With Quote
Old 10-29-2008, 03:53 PM   #6
kulturekat
kulturekat's Avatar
awesome thank you so much for that picture thall help a bunch
Old 10-29-2008, 03:54 PM   #7
kulturekat
kulturekat's Avatar
where in oklahom are you at?
Old 10-29-2008, 04:03 PM   #8
1970heavychevy
busted knuckles
I almost broke mine before some one told me about that button. Pictures say it all.
Old 10-29-2008, 04:07 PM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it can be a total pain in the 12 bolt to remove, so be prepaired to try 5 or 6 times. Twist the knob, push, pull, and cuss.
That's the secret, you have to use the correct 4 letter words.
Old 10-29-2008, 04:33 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
If you pull it out, then press the button, it'll come right out the rest of the way.
Beat it to fit,
Old 10-29-2008, 06:26 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
He's right! I fussed and cussed until I found the right combination of phrases that worked.
Oh, the wiper knob has a set screw that enables you to remove the knob. You have to do that before you can access the nut that holds the bezel and switch in place.
Member Nr. 2770
Old 10-29-2008, 06:33 PM   #12
drewdude92
72 chevys 4 life
drewdude92's Avatar
yup the first time i was pulling the light switch thing out i thought i was about to break it i just pulled and pulled then went to this website and figured it out =) i love this place
I dont call it being young and dumb....I call it young and havin fun
drewdude92 is offline   Reply With Quote
Old 11-01-2008, 09:55 AM   #13
Aarons72s
Yah I love those headlight switches. I have only had one pull out the first time while pushing the button. Most are a pita! If all else fails I pull hard enough on the knob and the knob pulls of the end of the shaft. I then finish pulling the switch and fight with it once it is out of the dash. Once the shaft finally comes out of the old switch I then tap it back in the knob and slide it in the new switch.
Aarons72s is offline   Reply With Quote
