Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-30-2008, 04:38 AM   #1
WhiteStar
Bolt In 12 Bolt Or 9" Rear
Anyone have Leeds on who Might offer a Bolt in 12 bolt or 9" For a 1970 GMC? I Would Be needing one for an N20 496" Application, w/ spool Heavy axles etc. Also was wondering if theres any benifit to setting a coil over shock set-up on the same? Thanks..
WhiteStar is offline   Reply With Quote
Old 10-30-2008, 08:11 AM   #2
djracer
djracer's Avatar
Re: Bolt In 12 Bolt Or 9" Rear
I would older a 9 inch from Moser what ever width you wand then do trailing arms coilovers and an anti roll. I think you will have wheel hop with the leaf springs.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-30-2008, 09:59 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
I'm really happy with the Moser 9" in my camaro......
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 10-30-2008, 10:29 AM   #4
WhiteStar
This Truck is a coil spring rear, it may be a 69 model,but either way I was looking to see if anyone offered a prefabbed bolt in deal?Thanks For the reply or any other insight.
Old 10-30-2008, 10:48 AM   #5
djracer
djracer's Avatar
Not hardly anyone leaves these trucks stock height and I think the varying ride height would cause pinion angle problems. If you order a housing the right length the only welding would be the pan hard bar and the saddles for the trailing arms.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-30-2008, 11:37 AM   #6
WhiteStar
yeah, I allready have a set of trailing arms and a 4-6 lowering kit from CCP,as well as the cross frame bar where trailing arms attach,what the trick to setting the pinion angle if I Get a 9" and weld the mount points on for the trail arms? Get it all in there and tack it where it looks good? I Have a Lift and transjack here at the house so it would be fairly easy.
Old 10-30-2008, 02:15 PM   #7
djracer
djracer's Avatar
you can probably bolt it up without tacking it till you set the angle with a gauge. You really need a lift that leaves the chassis loaded like they use at allot of muffler shops. Or jack it up and sit it on cinder blocks or wood boxes.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-30-2008, 07:17 PM   #8
kwhite4
Junior Member
kwhite4's Avatar
I also have a Moser Fab 9 in my truck. Truck had leaf springs but I went with ladder bars that are fully adjustable, works well for me so far.
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
Old 10-30-2008, 08:01 PM   #9
Garagedude
Garagedude's Avatar
I have a 12 bolt eaton posi, richmond gears, moser axles and its held up fine but then again I haven't thrown 700 horses at it either.
Garagedude is offline   Reply With Quote
Old 10-30-2008, 10:35 PM   #10
djracer
djracer's Avatar
I have beat on a couple of 9 inches and they are tough.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-31-2008, 03:27 AM   #11
WhiteStar
Thanks for the replies.Motor Came off the dyno Today,Wasnt terribly Impressive, 614 Hp at 6000, and 625 Ft Lbs at 4000, Hopefully N20 will get it in The 800HP Range, Trying to go for the sleeper no roll cage,Spare Tire Bolted in the Bed ,Carry The front wheels Past The 60 Ft Beams Look/Approach. We shall see ,I guess.
Old 11-12-2008, 02:06 PM   #12
Ont67shortbox
Moser,DTS or Currie all make housings to fit our trucks.DTS did the rear for Copperhead,I think they are located in Michigan,Brian
Ont67shortbox is offline   Reply With Quote
Old 11-13-2008, 12:15 AM   #13
Super73
Super73's Avatar
You big block guys are making me think I should sell my LS1 and go old school big block. But then again, it is fun seeing the face of some big block guys when I go around them. I thought I was going to get pounded by a very nice sounding big block on spray. Ended up passing him by the 1/8 mile marker.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
