Old 02-21-2003, 11:57 AM   #1
lotik
drag it like you stole it
for those of you with shaved door handles..
i got my kit in, and had a guy i know come align the doors for me. i put new rubbers in the truck as well. now the damn poppers can't pop the doors open. the rubbers are really stiff. if i take the rubbers out the door will pop open just fine. anyone else had problems with this? btw i am using the custom classic kit with 35# solenoids and will be puttin their poppers in as well.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 02-21-2003, 02:36 PM   #2
orange72
orange72's Avatar
are you saying the soleniods wont pop the door open or the little spring loaded pusher wont pust the door open. if the soleniod wont pull the latch then that means it aint strong enough. more than likely the new rubbers are putting some tension on the latches. if thats the case try pushing in on the door and then hitting the switch to see if it unlatches it. if its just the springs get some bigger ones. i got my poper kit from summit. its the vpa kit. the offer some big springs for the doors. hope you figure it out.
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4.
orange72 is offline   Reply With Quote
Old 02-22-2003, 12:42 AM   #3
GREEN70-72
GREEN70-72's Avatar
ORANGE72 YOU WOULDN'T HAPPEN TO HAVE THE WIRING DIRAGRAM HANDY FOR THE VPA KIT WOULD YOU? I HAVE THERE KIT IN MY CAR AND NEED TO MAKE SURE IT IS HOOKED UP RIGHT OR IF IT IS JUST FRIED. IT HAS BEEN 5 YEARS SINCE I PUT IT IN.
THANKS
GREEN
GREEN70-72 is offline   Reply With Quote
Old 02-22-2003, 02:47 AM   #4
orange72
orange72's Avatar
yea i think i might still have it..ill have to go look in the shop tomorow to see though so no promises.
Old 02-22-2003, 10:30 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
If it's the door jam weatherstripping that's causing the problem, you need to re-adjust those doors or the striker plate.
Mine were the same way when I installed new rubber but after a week of slamming doors, I decided to try another adjustment.
I found my problem was in the stiker adjustment. After I moved it out a bit, the doors worked perfectly.
You probably have too much outward pressure from the rubber and that makes the door buttons hard to push to open the door.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
