engine question
Help me diagnose...truck starts fine, runs fine, doesn't seem to be leaking anything...i had the carb rebuilt, but now that I got it back, it makes a clacking noise while running....runs and idles strong and smooth, but loud noise....if you give it gas it smokes a TON, doesn't seem to really smoke a lot while idling...HELP
Re: engine question
what color is the smoke? white,black or blue
Re: engine question
I may be way off here, but the people who did your carb may have dropped some thing down the intake like a washer or nut.
77 Cheyenne no longer in bits ![]() |
Re: engine question
who knows if he dropped anything, if he did i'd be pissed to say the least....the smoke is grayish in color...any ideas?
Just here to tinker
![]() Join Date: Jun 2008
Re: engine question
Man this is weird! I just did the same thing this morning on my pick-up. I built a new carb and put it on and then after a couple minutes a crap load of white smoke and a bunch of clattering. I must have dropped something.
Best of luck to you, I would take it back!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
#6 | |
Old Shovel Rider
Re: engine question
That's a scary thought, but it's possible. That would be loud. It sure will be a ***** to pull the manifold/heads to find out. Whitish/gray smoke usually means you're running too rich. You might be able to narrow down the source of the noise with a sethoscope. +1 on taking it back. If it was fine before and it's clacking now, I'd get it back to them and have them check it out before too much time passes and they blame it on you. Last edited by DB Smith; 11-02-2008 at 08:23 PM. |
Re: engine question
if something was dropped, it should sound something like popcorn popping, kinda sporadic......
Re: engine question
this isn't a popcorn sounds, it's a more constant noise...any more ideas?
Re: engine question
Noise could be a loose rocker if the frequency of tapping increases/decreases with engine RPM. Improper air/fuel in combustion chamber may result in improperly burned fuel exiting exhaust... possible explanation of gray-ish smoke.
I'm no certified tech, so please correct me if I'm wrong.
1986 Chevy Silverado (RCSB) - 5.3L/4L60E nearly complete... ![]() Last edited by 1BadC10; 11-06-2008 at 04:41 PM. |
dang its hot
Re: engine question
something like a washer in the cylinder can bust a piston. pull the plugs and look at them, chances are if anything is in the combustion chamber, it has slapped the plug tip a time or two
Re: engine question
is it detonating?
Re: engine question
I don't think anything was dropped, but the loose rockers sounds like a possibility...is that an easy fix? Pop the valve cover off and tighten or more in depth?
Old Shovel Rider
Re: engine question
More in depth.
You can do it with the engine running. Make sure to get it up to operating temperature first. Then pull one of your valve covers, You can get a set of clips at pretty much any auto parts place. They will keep it from spewing oil all over the place. If you have an old set of covers they can be cut to keep the oil under control. Do one bank at a time. Do one rocker at a time. Loosen the rocker nut until you begin to hear it clatter, then slowly tighten until the clatter just goes away (that's about 0 lash. Then tighten the nut 3/4 turn. Then move on to the next one, and the next, an so forth. Check out this video.... If you have "Cool Nuts" you will need an allen and a box end to do the adjustments and lock them down.. ![]() The valves can be done cold too. I only do it this way on a new build on the engine stand. 0 deg TDC on #1, both number one valves shut. Adjust each push rod on the first list to zero lash (barely able to spin it with you fingers) then tighten 3/4 turn Adjust the #1 exhaust valve Adjust the #1 intake valve Adjust the #3 exhaust valve Adjust the #5 intake valve Adjust the #7 intake valve Adjust the #2 intake valve Adjust the #4 exhaust valve Adjust the #8 exhaust valve Now rotate the engine 360 degrees. The mark on the balancer should be back at the TDC mark. Keep in mind that this is not the TDC where #1 would be firing! It's where #6 would fire. Adjust each push rod on the second list to zero lash (barely able to spin it with you fingers, then tighten 3/4 turn Adjust the #3 intake valve Adjust the #5 exhaust valve Adjust the #7 exhaust valve Adjust the #2 exhaust valve Adjust the #4 intake valve Adjust the #6 exhaust valve Adjust the #6 intake valve Adjust the #8 intake valve Last edited by DB Smith; 11-07-2008 at 12:57 AM. |
