11-03-2008, 11:25 AM | #1 |
Red Headed Step Child
Oil Leaks... make it stop!!!
Ok.. I'm just ranting but I have the worst luck with oil leaks.. Driver side valve cover a month ago. Get it fixed and now it seems the passenger side has started.. Oil leaks drive me bonkers..
"Dinner, the perfect break between work and drunk" -Homer Simpson |
11-03-2008, 11:29 AM | #2 |
Parts and more parts
Re: Oil Leaks... make it stop!!!
SO, when faced with a aleaky valve cover, you did NOT change both of them out at the same time. now you have a leak on theother side? I would have done both myself, of course that is just me.
11-03-2008, 11:41 AM | #3 |
classic=of recognized value
I have been chasing leaks as well. I have replaced the valve cover gasket, the push rod cover gasket, the rear main seal, and the oil pan gasket all in the last month. I have slowed river of oil down, but I doubt it will ever end (at least not for this engine). I like to think of it as my truck "marking it's territory".
11-03-2008, 11:43 AM | #4 |
Why change both if only one side is leaking?? I added some dye to the oil and then used a blacklight to track it down. I've never been very good with seals so I let a shop do this one. Going to let them do the other side also b/c if I do it it's just going to leak again
11-03-2008, 12:02 PM | #5 |
Why change both? Well if it were me, I'd change both. If they're the same age and one goes out...it's pretty much a sure thing the other is going to go out. At least that's my experiance with Murphy's Law.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
11-03-2008, 12:13 PM | #6 |
My thinking is never pay twice for a job done once--while doing the job, the gasket set comes in pairs and they had the mechanic standing there doing the job. It would only cost a little bit more for the second cover, now it is another complete stop over at the shop and they start from the beginning--time lost and a little more cost. Just my .02 worth.
11-03-2008, 12:38 PM | #7 |
Do it one time and do it correctly!!!!
Works for me....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
11-03-2008, 12:38 PM | #8 | |
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
11-03-2008, 02:21 PM | #9 | |
Seriously though.. I've done what you said. I've used cork gaskets, rubber gaskets, prematex on multiple different valve covers. I seem to always screw it up. If it costs me $100 to have it done and NOT leak then it's worth it IMO. At least I can go after the shop to do it again if it continues to leak. This engine has less than 10k miles on it. It's a GM 350 from the local chevy dealer. It shouldn't be leaking I don't think
11-03-2008, 03:07 PM | #10 |
Do you have chrome valve covers? If so they are notorious for leaking. I wont use chrome for that very reason. Leaks everytime. I have ground the chrome off the mating surface and used some good old gorrilla snot on the cover side and it will usually hold. I prefer cork and paper myself but to each his own. My shop teacher once told me in high school it may look perty but "Chrome dont get ya home!!!"
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
11-03-2008, 04:21 PM | #11 |
Moderator
Use the rubber gaskets with metal inserts in them (Fel-Pro). Cost around $30 but you get what you pay for. My 72 has the OG 350 and does not leak a drop. You do not need to apply sealer or over-tighten the bolts. If your covers are bent, they will NOT seal properly. I have the stock OEM valve covers...never had any luck with aftermarket ones. Cork is very porous and just absorbs oil, and eventually it will start to leak. This is of course my opinion, but it is a FACT my valve covers did not leak after I changed to the rubber gaskets.
11-03-2008, 04:49 PM | #12 |
Valve cover gaskets are on the list of things my dad always told me to change in pairs. Just like brakes, tires, headlights, and radiator hoses.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown '70 SWB Step-Side (More rust than metal) |
11-03-2008, 05:27 PM | #13 |
most valve cover leaks are from the over tightening of the bolts which causes the bolt holes in sheetmetal valve covers to dimple out causing the leaks it happens far less when using quality cast covers.
45INCH pounds of torque
11-03-2008, 09:06 PM | #14 |
Wow!
myspace.com/southtacomaalleyrally |
11-03-2008, 09:18 PM | #15 | ||
Sierra Grande Club
BTW when I wanted to replace my timing chain cover I had to look hard for a Non chrome timing cover.....all the stores had chrome, and I won't use it. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 11-03-2008 at 09:20 PM. |
11-03-2008, 09:23 PM | #16 |
sharp as a marble
Make sure the PCV system is working. Don't know how many times my shop used to fixed oil leaks by replacing PCV valves. Not so common any more, but might be relevant here. Pcv should be sucking thru one Valve cvr, and you should be able to lay a rag or a small piece of paper on the OTHER valve cvr, and see it suck in. this will give you an idea the PCV is working. If the PCV is not working the engine will build pressure, and push oil from the weakest link.
11-03-2008, 09:33 PM | #17 | |
Moderator
11-05-2008, 12:13 PM | #18 |
PCV is working and no chrome valve covers..
Water pump is leaking also so going to replace that also.. Sheesh
