Old 10-27-2001, 10:03 AM   #1
barn9
Half a bubble off!
barn9's Avatar
Post 2.8 v-6 engine replacement options
I posted this question a couple months ago, and then lost the info you guys provided because of a computer crash. I have a weak 2.8 in a 1987 S-15 Jimmy, and need some ideas about upgrading to gain some power. I do not want another gutless 2.8. I appreciate your help, and I will print the info this time. Thanks!
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 10-27-2001, 10:58 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
A small block is not hard to do. They say a Ford Tempo radiator, stock exhaust manifods, and better front springs is all you need.
If you have a 4 or 5 speed, it would be wise to swap to either a stronger tranny, or an automatic.
Old 10-29-2001, 03:44 AM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
problem is the bellhousing bolt pattern, he would have to swap in a 4.3L V-6 or larger tranny to install a V8. have same dilemma in tthis 85 4x4 Cherokee out here, has a GM 2.8L with a Chysler 904 bolted to it, an oddball deal...the tranny is bad and 2.8 has 197k on it, its tired, I dunno how its even stil alive..I dont think the NP207 T-case could handle a V8.
I think the only engines were offered were the 2.5L Tech-4, the pos 2.8L V6, and the nice little 4.3L V-6,,,,, and thats it for the S series truck engine choices, 82-up of course.
Randy- Lincoln, IL
r68c30@hotmail.com -------------
Fleet, currently:
68 C-30 dually dump, driver
72 K5 chassis; partially disassembled
79 G10 sportvan, driver
77 Electra boatcar, driver
76 1500 in pieces, scrap
68 C10 in pieces, scrap
America and 68's rule !
Fast68Chevy is offline   Reply With Quote
Old 10-29-2001, 10:24 AM   #4
78KustomKlassic
Post
Hey barn9-
Summit carries S-series SBC conversion kits that include motor mounts and tranny mounts for a TH350. If I remember right, the kit is only about $60. Some day I'm going to start a project like that too. Good luck, man!
Here's Summit's website in case you don't have it: http://www.summitracing.com
joel
78 C10
Currently: 250/TH350
joel
78 C10
78KustomKlassic is offline   Reply With Quote
Old 10-29-2001, 10:46 PM   #5
barn9
Half a bubble off!
barn9's Avatar
Post
Thanks guys, but I am thinking more of a replacement V-6 like a 3.4 or something that will bolt right in. Someone had some info about that changeover, but I lost it when my computer crashed (damn webshots). Anyone?
Just call me LB.
Old 10-30-2001, 08:52 PM   #6
Longhorn Man
Post
Fast, they also had an Isusu 1. something in the early '80's truck...wasn't even worth remembering.
The 2.5, i believe, had the small block belhousing size.
Old 11-03-2001, 03:15 AM   #7
Tom
driving is in my blood
Tom's Avatar
Post
heres an option. Take your stock 2.8L. Get some camaro or pontiac fiero 2.8L heads. they have bigger valves. Add a compression ratio of about 9.5:1. Take the crank and pistons out of a 3.1L, they will swap right in and give you a normal 3.1L v6. Add a bigger cam, and some headers. Maybe even port the heads. You should get somewhere around 180-195hp if done right with much more torque.
The 3.4L will bolt right in, and it has a warrenty. A 4.3L v6 should bolt right in also, with a tranny change.
1978 chevy c10
383 stroker,10:1 compression,vortec heads, roller rockers,performer RPM intake, holley 750DP, MSD ignition,comp 280H cam, headman headers, muncie four speed, 3.73 12 bolt rear.
Old 11-03-2001, 06:05 PM   #8
Longhorn Man
Post
Just be warned, the 2.8 and 3.1 both have VERY weak cranks.
The hot rod;
a'69 G.M.C. Short/Fleet. 350 W/a heluva cam and nice stance. Still a beater though. Trying to clean up the left over damage from the Dope-Smokin-Old-Man...a real bummer. See it at http://geocities.com/andys_69_gmc/
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. Check out my Longhorn site at http://geocities.com/MotorCity/Flats/8752/
IM me on Yahoo pager...cockroach93.
hey, stop laughing!!!
Old 11-12-2001, 06:46 PM   #9
R. L. Jaeger
Guest
Posts: n/a
Post
Check the GM performance parts catalog at your Chevy dealers for their 3.4 version of the 2.8L engine... this is not the dual overhead cam version, but will give you a lot more power without the hassle of putting in a sbc V-8. Just another option for you...
Good luck!
