Old 11-04-2008, 01:02 AM   #1
gottwake
gottwake's Avatar
can you mount rack and pinion to stock crossmember?
Just wondering if this is possible.
Blazer Project
gottwake is offline   Reply With Quote
Old 11-04-2008, 01:37 AM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: can you mount rack and pinion to stock crossmember?
Possible, but a lot of work to get it set-up properly.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-04-2008, 09:19 PM   #3
joe231
joe231's Avatar
Nate, can you elaborate?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-05-2008, 01:09 AM   #4
PBFAB.COM
PBFAB.COM's Avatar
The most difficult part is locating a rack with the proper inner to inner pivot dimensions, that can be easily mounted in the proper location. If I recall correctly the inner to inner tie-rod pivots on the factory drag-link is 24". Mustang, and a few other racks can be purchased with this same inner tie rod length (The mustang being the most common, and the most affordable). The only problem is that when the rack pivots are located in their proper position (X, Y, Z coordinates) it puts the rack mounts in the u-bolts and crossmember. There's ways to do it... it just becomes involved.
I looked into doing this mod a long time ago, and ended up going another route.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 11-05-2008, 01:19 AM   #5
joe231
joe231's Avatar
thanks for the info
CHEVY ONLY
Old 11-05-2008, 09:46 AM   #6
jlaird
jlaird's Avatar
something tells me you're other route was the better route!
jlaird is offline   Reply With Quote
Old 11-05-2008, 09:55 AM   #7
SCOTI
SCOTI's Avatar
Good enough for cloning . . ..... .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-05-2008, 11:28 AM   #8
jlaird
jlaird's Avatar
Ha Ha, didn't get that at first. Very funny Scoti!
Old 11-05-2008, 11:34 AM   #9
joe231
joe231's Avatar
sheesh, here you guys go turning another thread into a Nate-worshiping, man-crush thread
CHEVY ONLY
Old 11-05-2008, 01:02 PM   #10
SCOTI
SCOTI's Avatar
No worship or man-crush here.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-05-2008, 11:16 PM   #11
gottwake
gottwake's Avatar
Cant you just weld on a tab or something to the crossmember and attach it that way?
Blazer Project
Old 11-05-2008, 11:31 PM   #12
joe231
joe231's Avatar
i tried to get on here before you edited and added "or man-crush"
just poking fun......
gottwake, believe the problem is not the actual mounts, but the fact when you have the rack where it needs to be, the lower control arm u-bolts cause interference, so you will have to modify how the lower control arms attach to the cross member
CHEVY ONLY
Old 11-05-2008, 11:33 PM   #13
SCOTI
SCOTI's Avatar
Yeah... I read that & thought "uh-oh, better edit that one" FAST!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-05-2008, 11:44 PM   #14
joe231
joe231's Avatar
CHEVY ONLY
Old 11-06-2008, 10:42 AM   #15
gottwake
gottwake's Avatar
Fair enough Joe 231. All hopes crushed, in a single response...
Blazer Project
Old 11-06-2008, 11:13 AM   #16
joe231
joe231's Avatar
I don't think anyone is saying it can't be done....anything is possible
cause you know, It is only metal
Not to the point of doing the rack yet, but fellow board member Scotts62 is planning a rack and pinion on his '62 with a '73-up stock cross member and custom frame......
CHEVY ONLY
Old 11-06-2008, 11:25 AM   #17
scotts62
One day...
scotts62's Avatar
Yep im going to work on it gottwake if that makes you feel better about trying it
Scott
93 crew cab build
Project 62
Old 11-06-2008, 01:37 PM   #18
gottwake
gottwake's Avatar
Sweet. You can practice on mine if you want?? Your not too far away...I actually used to live in Ardmore, OK
Blazer Project
Old 11-06-2008, 05:23 PM   #19
joe231
joe231's Avatar
CHEVY ONLY
Old 11-06-2008, 06:21 PM   #20
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
I did mine like stated and it works perfectly fine. see my build thread
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 11-06-2008, 09:11 PM   #21
scotts62
One day...
scotts62's Avatar
Thats cool,
Heck yeah put a stamp on it and send it on over!
Scott
93 crew cab build
Project 62
Old 11-07-2008, 12:08 AM   #22
gottwake
gottwake's Avatar
Camaro thunder...man that is bad a$$. How did you do that? What R&P is that out of?? Take some close ups for us!!!
Blazer Project
Old 11-07-2008, 01:36 AM   #23
joe231
joe231's Avatar
CHEVY ONLY
Old 11-07-2008, 12:57 PM   #24
scotts62
One day...
scotts62's Avatar
x3
Scott
93 crew cab build
Project 62
Old 11-07-2008, 02:02 PM   #25
camaro__thunder
I will as soon as I can.
Really busy getting both trucks ready for the show on Nov. 15th.
My Project 69 SWB
