Old 11-04-2008, 09:52 PM   #1
pete29
when truck is put in gear it spins the tires
I just got the engine and trani in my truck i am redoing and tried to take it out for a spin, but when put in gear it spins the tires and takes off. I can't hardely stop it unless i put in neutral it looked like the trani fluid may be a little low, could this be the problem, or is it some thing else. Also how important is the hose that connects the booster brake cylinder to the carb.
pete29 is offline   Reply With Quote
Old 11-04-2008, 11:09 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: when truck is put in gear it spins the tires
I kind of have the same issue, and I think that it might have to do with "my" carb/vaccum/brakes/booster. I already know that I have issues with my carb and the choke, so it's running at a higher rpm, but sometimes when it's running at the higher rpm it will take quite a bit longer for it to stop.
bump for some answers for pete29
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-05-2008, 09:52 AM   #3
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
rpm to high turn idle screw all the way out
Trans kick down mite be stuck
mite not have any back brakes
Gary 70 Jimmy is offline   Reply With Quote
Old 11-05-2008, 08:43 PM   #4
dirty trucker
dirty trucker's Avatar
The hose that connects the booster to the carb is VERY important...
Without that connected you have NO vaccum for your power brakes. The whole spinning the tires thing doesn't sounds right though. I would think your blazer just wouldn't stop if vaccum were the problem.
dirty trucker is offline   Reply With Quote
