Old 11-05-2008, 04:30 PM   #51
hdflstf
hdflstf's Avatar
Re: Calling All 383ci Trucks
Nice thing about the 383 setup is the big fat torque curve Over 400 ft-lb through most of the rpm range. That'll move your truck in any gear. Of course, too big a cam will kill that in a hurry.
hdflstf is offline   Reply With Quote
Old 11-05-2008, 04:34 PM   #52
70rs/ss
70rs/ss's Avatar
Originally Posted by WorkinLonghorn View Post
70rs/ss; I'm sure this has been beaten to death elsewhere but if he uses Vortec heads, will his accessories bolt up or not?
Also he'll need vortec intake.
Accessories will bolt like any SBC, they have the same bolt holes as all SBC heads do, and they take a normal or reversed water pump so , litterally the 67-72 accessories bolt on and work as is. Yes, he'll need a Vortec intake $130 new, so no real increase in $$$, but all the benefit outweighs the extra $$ IMO since a roller cam, and never worrying about a flat lobe in and of itself helps me sleep at night.
70rs/ss is offline   Reply With Quote
Old 11-05-2008, 04:40 PM   #53
70rs/ss
70rs/ss's Avatar
Originally Posted by VDOG View Post
Thanks guys. Now what im reading is im ok with my th350 trans but none of you are running 3:08's. I see 3:73's are the perfered gear for a 383 motor.
Which since it was rebuilt last year, I dont want to spend more money to change it. Again not opposed to the 383, and long as I cant get the right combination to work with what I already have installed.
No one is saying you have to have 3:73's, they are saying they have them, which makes the motor spin faster at cruize than your 3:08's which means in your application the 383 will be barely breathing at a 70mph cruize and last even longer?? I said 3:08's would be near perfect, since the 383 has a lot of torq (read: low end grunt!) to move the vehicle and on the top end cruize you'll be running the 2k rpm range. You are reading too much into this, we all have different gears, that doesn't stop us from running a similar motor, it just means some of us will run a higher RPM at cruize and twisting them higher longer is harder on them, so if these guys with 3.73's and 4.11's are not breaking them your 3.08 at cruize will never break it??
Old 11-05-2008, 05:44 PM   #54
67chevemall
67chevemall's Avatar
I took mine 1500kms from Niagara to Daytona Beach with 4 speed M21 and 3:73 gears...now I have 3:07 gears and man it is a highway machine now....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 11-05-2008, 07:05 PM   #55
VDOG
Grand PooBaa Member
VDOG's Avatar
I understand now. I was told 3:08's make there own power so with that engine and my setup of gears and trans, I would have a nice torq and freeway-able without worrying about tearing up the engine.
VDOG is offline   Reply With Quote
Old 11-05-2008, 07:07 PM   #56
VDOG
Grand PooBaa Member
VDOG's Avatar
Thats my problem with my 283, the cam is so big (not sure what size) that I have only top end power. No grunt at all. The guy who built this had it in his Chevelle with a manual trans.
Old 11-05-2008, 07:52 PM   #57
piecesparts
Parts and more parts
piecesparts's Avatar
385 Cu In stroker motor with Comp Cams roller cam and rocker arm setup, Edelbrock Performer RPM intake, "Carb Shop" billet dizzy, Edelbrock AVS 650 carb, and Moroso 7 quart oil pan.
This is the second engine that I have built like this and the driveability is better than a normal 350 and has more low end torque than needed. I am running a 700 R4 with 3.73 gears and 28" rear tires. Highway RPMs are at 2500 RPMs at 70 MPH with the gas mileage at 15 MPG. I have had this truck all over the country on numerous Hot Rod Power tours.
Old 11-05-2008, 08:06 PM   #58
VDOG
Grand PooBaa Member
VDOG's Avatar
Thats a helluva motor. Im convienced, 383 it is. Cause I do want the torq and power and if I get it built for reliablity and for light to light, I should be ok.
Thanks.
Old 11-05-2008, 08:11 PM   #59
ratpackv8sonly
ratpackv8sonly's Avatar
I have a 383 in my 69 as well. 700R4 with 4:11s and on the hwy it was getting 18mpg. Offey intake with a Q-jet and points. Its a good truck engine with alot of torque an you should be happy with it in yours even with the 3:08 gears. But then there is nothing wrong with a good 350 engine.
ratpackv8sonly is offline   Reply With Quote
Old 11-05-2008, 08:40 PM   #60
piecesparts
Wow, 18 MPG with 4:11 gears, the tires must be pretty tall, to get that. That is a good thing, that you can do that. The Q-jet is part of the combination that helps in that area.
With a set of 3.08 gears, don't overdo the cam choice. The gear ratiio will kill your take off and screw up the gas mileage. My son's truck had 3.08 gears and when we put an OD tranny in it, the RPMs fell to just under 1800 at 70 MPH. The mileage also dropped off. We put a set of 3:73 gears in it and gained back 2 MPG and it is a strong running 350 truck.
Old 11-05-2008, 08:54 PM   #61
VDOG
Grand PooBaa Member
VDOG's Avatar
Options Options!!
I just know its time to get out of the 283!
Old 11-05-2008, 09:36 PM   #62
huero
1969 Short, Fleet, and Beat
huero's Avatar
Originally Posted by Ricks1971 View Post
then just build a nice 350 then.That way you don't have to pay for the extra balance work.
x2. Nothing wrong with a stock 350 or one with a mild cam.
huero is offline   Reply With Quote
Old 11-05-2008, 09:43 PM   #63
huero
huero's Avatar
Options Options!!
With todays gas prices a 283 with 3.08 gears sound like a nice combo to me. But, I am just a old dude with little $.
Old 11-05-2008, 10:10 PM   #64
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
then just save some money and change the cam in your 283?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-05-2008, 10:24 PM   #65
hdflstf
hdflstf's Avatar
Next time you're out my way, let me know. We can go for a test ride.
Old 11-05-2008, 11:03 PM   #66
prg machine
prg machine's Avatar
Here she is
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 11-06-2008, 08:47 AM   #67
Actually 3.08s would be prefered by most,I`d think.3.73s were standard,maybe that`s why most have that ratio.Figure GM used 3.08s with the torquey big blocks.Better torque allows taller gears.
Old 11-06-2008, 01:38 PM   #68
VDOG
Grand PooBaa Member
VDOG's Avatar
Same here. Old dude no money!
Old 11-06-2008, 01:40 PM   #69
VDOG
Grand PooBaa Member
VDOG's Avatar
Dont think that has not crossed my mind. I still might do a refresh in my 283 and change the cam for now since money is very tight right now.
Old 11-06-2008, 01:41 PM   #70
VDOG
Grand PooBaa Member
VDOG's Avatar
I can make a trip out your way. Always looking for a reason to cruise.
Old 11-20-2008, 01:19 PM   #71
Kabwe
Certified Car Nut
Kabwe's Avatar
Vdog,
Build the 383, you know I would not steer you wrong. You will be very happy with it. I'm thinking about building one for the 55 Chevy truck, the 5.3 might be going in another project.
Kabwe is offline   Reply With Quote
Old 11-20-2008, 03:44 PM   #72
70rs/ss
70rs/ss's Avatar
I'd bet you could build a 383 for close to the price of a rebuild on the 283 and you are giving up 100 ci!! Do like I did amass the 383 piece by piece, just be sure to buy the rotating assembly matched or you could end up spending all the $$$ you saved getting it balanced!
I built a pretty wild iron vortec headed 383 and the machine shop bill with parts ready to assemble was $2600. Sounds expensive but I rework ever piece and part, ported heads, bowl blended them, screw in studs, guide plates, Mutha' Thumpr" roller cam, screw in studs, etc, etc,etc!!
Old 11-20-2008, 04:31 PM   #73
VDOG
Grand PooBaa Member
VDOG's Avatar
All you guys make a strong point for the 383. Again if it will work with the gear and trans I have, then I will go for it. Other than that, a stout 350 will go in and I will be done with it.
Old 11-20-2008, 07:35 PM   #74
VDOG
Grand PooBaa Member
VDOG's Avatar
Originally Posted by Kabwe View Post
Vdog,
Mr Kabwe, I know you got my back, im just waiting on you to start the bodywork. LOL
The engine is going to have to come soon since im getting blowback from the current 283. Again if it works with my setup, then lets build it.
Old 11-20-2008, 08:16 PM   #75
WorkinLonghorn
WorkinLonghorn's Avatar
VDOG, I blew the original 350 ci engine in my '69 (full throttle with a load up the steepest hill in Los angeles,Baxter St,) and had a "rebuilt" 350 put in and opted for the "RV cam".(specs unknown). I am VERY happy with this 350 and it has loads of low-end torque. I've never driven a 383 to compare it with, but the only reason I WISH I had gotten a 383 is if I ever want to tow a travel trailer of any size,it would probably struggle up the long mountain grades.
But for all other uses,including bed-loads of sand,dirt etc.,I like my 350 just fine.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
