Old 11-05-2008, 06:30 PM   #1
Senator350
Senator350's Avatar
shortening steering column Q?
easy enough. took me about an hour to get the collumn out, grind the weld where the PO joined the intermediate shaft... shortened a little over an inch...
welded them together again. any reason i shouldn't have?
i never saw anyone tell of joining the shafts after shortening to desired length.
RN U OVR
Senator350 is offline   Reply With Quote
Old 11-05-2008, 06:55 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: shortening steering column Q?
ummmmm, can you show us a photo of what you are cutting and welding? There should be no reason co cut or weld anything for this mod.
Old 11-05-2008, 07:08 PM   #3
Senator350
Senator350's Avatar
the PO used the column from a different truck, and made it the length he wanted. when he got it to the desired length, he welded right where this arrow points:
so... i ground his weld off, and shortened more, and rewelded in the same spot.
RN U OVR
Old 11-05-2008, 07:19 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Um, yeah.... that's not suppose to be welded!!!!!!!! It is suppose to collapse into itself. It's a safety feature designed to keep the steering column shaft from becoming part of your sternum in a front end accident.
If I were you, I would get another intermediate shaft, and collapse it by drilling out the 4 plastic pins then giving it a good whack on the shop floor.
** Edit - Or, at the very least, pull it back out and grind the weld off and clean it up to the point where it WILL slide in and out, then reinstall it.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 11-05-2008, 07:28 PM   #5
Senator350
Senator350's Avatar
i just put a quick 1/4" bead. barely more than a tack.
it'll actually grind off while still installed. i made sure of this before i put it back in truck... easier for me to grind it installed than weld it installed
i KNEW in the back of my mind that the reason nobody talked about fastening the shafts was because it isn't needed.
thank you, kind sirs
RN U OVR
