Old 11-05-2008, 08:06 PM   #1
72 Super
72 Super's Avatar
72 Chevy 4x4 (converting 4 speed to automatic)
What all is involved in converting a 71-72 Chevy 1/2 4x4 ton from a factory 4 speed to a automatic. I mainly need to know is the transfer case and drive shafts the same? Other than the trans and related items what else would be needed? I know the column and pedal set up would be changed.
Thanks,Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 11-05-2008, 08:36 PM   #2
drbyrdman
drbyrdman's Avatar
Re: 72 Chevy 4x4 (converting 4 speed to automatic)
Iam doing one right now. Just take the clutch rod out and patch the hole in the fire wall,remove the clutch pedal and plastic bushings, get a auto floor shifter of some kind (B&M has a truck mega shifter that works good and does not cost alot), your going to have to move the transfer case mount and lengthen or shorten the drive shafts depending on what tranny you use. I would do some searching around and find a 350/205 or 400/205 combo for sale or do what I did and get a turbo 400 tranny and a tranny adapter to put a 350 or 400 tranny to the 205 transfer case.
drbyrdman is offline   Reply With Quote
Old 11-05-2008, 11:12 PM   #3
kwmech
If you go with the turbo 350 the overall length will be the same
Old 11-06-2008, 09:01 PM   #4
72 Super
72 Super's Avatar
Kwmech, I was planning on going with as turbo 350 trans/ with a 205 transfer case. So the drive shafts will be the same?
Drbyrdman, was you truck a factory 4x4? This seems like alot of changing for me. I was hoping that all was needed to be done was changing the trans and transfer case.
Thanks,Ray
Old 11-06-2008, 10:01 PM   #5
72 Super
72 Super's Avatar
72 4x4 converting a factory 4 speed to an automatic
I posted this in the 4x4 section as well,just trying to get alittle more info. I am looking at 72 4x4 that is a factory 4 speed. Are the driveshafts the same length from a 4 speed versus automatic truck? Would the tranfer case be in the same location? I am just trying to figure what all is involved in switching over a manual to automatic.
Thanks,
Ray
Old 11-06-2008, 11:06 PM   #6
It`s as simple as swapping the t-case/tranny combos and deleting uneeded manual pieces like clutch pedal & linkage and adding Automatic shifter.
Old 11-07-2008, 12:05 AM   #7
knsmodels
I make Models
knsmodels's Avatar
Re: 72 4x4 converting a factory 4 speed to an automatic
Pretty sure you need the the transfer case, tranny, and driveshaft from an automatic for the conversion......transfer case shifter should remain in the same location and 4-speed.......
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 11-07-2008, 12:31 AM   #8
drivethechevy
drivethechevy's Avatar
when i first picked up my 68k10 4speed a few months ago i was thinking of doing a swap to an auto, i determined that the best route was getting a tranny and tcase from a newer truck, and i was going to have a driveshaft built if needed, the driveshafts, the tranny xmember and the linkage's seemed to be the bigger problems
but nothing some drilling a floor shifter and custom drive shafts wouldnt fix
hope that helped you some
good luck
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 11-07-2008, 06:40 AM   #9
JimKshortstep4x4
The drive shafts are the same length so you can reuse them. Outside of the tranny and auto transfer case you will need the shift linkage and steering column. It is a pretty straight forward swap out.
My 71 snow plow had the manual (3) on the tree transmission that I swapped out and it sure is easier to plow with an automatic!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-07-2008, 08:38 AM   #10
Mudder
Mudder's Avatar
flex plate for the auto and you will be lucky if you don't have to alter driveshaft lengths. Oh tranny lines for the cooler.
when i did my daughters, I left the clutch petal and after disconnecting it stuck it under the carpet so that it would still be there if we ever wanted to go back to the 4 speed, which the son in law did.
Mudder is offline   Reply With Quote
Old 11-07-2008, 09:24 AM   #11
CUSTOM/10
CUSTOM/10's Avatar
I've done the same swap :
If the truck currently has an NP205 ( standard ) and your installing an NP205 ( auto & TH350 ) the drive shafts will remain the same, the cross member will remain the same & stay in the same location.
Other things you'll need:
auto steering coulomb
auto linkage & frame bracket
trany cooler & lines
kick down cable & brackets
flywheel
starter
flywheel cover
remove clutch peddle assem or you can install an auto brack peddle assem
patch floor hump or get a new one for an auto
The nutral safety switch is needed on the coulomb instead of on the trany
That's everything I can think of at the moment.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 11-07-2008, 09:26 AM   #12
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
That, and you might want to pick up a automatic 4x4 floor hump. Otherwise you will need to block off the stickshift hole.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-07-2008, 09:55 AM   #13
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
No the driveshafts are different, the rear shaft will have to be shortened. The 4speed trans is shorter than the 3speed.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 11-07-2008, 11:37 AM   #14
CPNE
Resident Curmudgeon
CPNE's Avatar
I believe JimK is correct. If you are talking about a swap from a 4speed/NP205 to a TH350/NP205, the driveshaft lengths are the same and the xfer case bolts in the same position on the frame. The difference in overall length between the two trannys is offset by the adaptor that mates the tranny to the transfercase.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-07-2008, 08:50 PM   #15
72 Super
72 Super's Avatar
Thanks for the replies. I would be going with turbo350/205 set up.I moreless had everything else in mind, I was mainly worried about the transfer case position and the lengths of the driveshafts.
Thanks,
Ray
Old 11-11-2008, 01:07 AM   #16
sweet70beast
sweet70beast's Avatar
Make sure you remove the pilot bearing from the back of the crankshaft or when you put in the auto the snoute on the torque converter fits inside the part on the same spot and will push on it and could shorten the life of your thrust bearing in your engine. Not to mention it might bend or crack the flexplate.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
