Old 11-05-2008, 10:41 PM   #1
k5hart
k5hart's Avatar
Is The Top A/C Bracket Needed?
Is anyone running the stock air conditioning without the top manifold bracket? Is there any problems with running without it?
I have tall valve covers and an Edelbrock Air Gap intake and both the bracket on the intake and the arm don't clear. I have all of the stock brackets holding the front and will be using a header adapter bracket on the bottom rear of the compressor.
Opinions. Thanks.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 11-06-2008, 08:37 AM   #2
k5hart
k5hart's Avatar
Re: Is The Top A/C Bracket Needed?
Bringing it to the top for the day. Anyone with thoughts?
Old 11-06-2008, 12:47 PM   #3
kxnomore
kxnomore's Avatar
I've seen this happen before with a Vortec cylinder head set up, where the brackets don't line up at all. But there are two upper brackets, right? The semi- straight one in the back that attaches to a C shaped bracket on the intake manifold. Do you have that one? If so, I think the remaing ones in the front are pretty strong, and you would be okay. You also could find another one of the straight brackets, or maybe an alternator's long curved bracket, and bend it to fit where the old top bracket was back to the engine on the front of the head or the manifold.
But if you have the back bracket I think you're good. Just my $.02
kxnomore is offline   Reply With Quote
Old 11-06-2008, 01:44 PM   #4
k5hart
k5hart's Avatar
kxnomore - Yes the two top brackets you talk about are the ones I want to eliminate. Good idea though using a modified alt. bracket or something. I am leaning toward trying it without and seeing what happens. Thanks.
Old 11-06-2008, 10:02 PM   #5
100%Chevy
I'd keep an eye on that sheetmetal header bracket.Without the top brackets,it will flex and crack.
Mike.
100%Chevy is offline   Reply With Quote
Old 11-07-2008, 08:59 AM   #6
k5hart
k5hart's Avatar
Good point. I'll check it every so often. Wish I could find an easy fitment for the top bracket.
Old 11-07-2008, 11:20 AM   #7
71 super
71 super's Avatar
Why not get two steel spacers 1/2 long by 3/8 to raise the bracket on the intake and clear your covers. the connector strap can then be pivoted to attach to the compressor. All you need is the spacers- lowes and longer bolts at the intake to account for the spacers.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 11-07-2008, 11:05 PM   #8
k5hart
k5hart's Avatar
I'll look at using some spacers tomorrow. Thanks 71 super.
