Brake Dust Shields
Anyone know of a place where I can get new brake dust shields for the front of my 87 1/2 ton 4wd? Only ones I found are way more then I wanna spend.
Thanks Nick '87 1/2ton 4wd-mild 355, TH400, long tubes, 3" single Magnaflow, manual locking hubs '88 SS-built 357, 2004r, 9.5" 3200 stall, 4.10 posi 8.5 '94 9C1-174k, built 4L60e, Hughes 2500 stall, 3.73 posi, 93oct tune, 2.5" true duals |
On a budget like Fred Sanford
Re: Brake Dust Shields
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
I guess I shoulda said front brake backing plates. These are the suckers that bolt to the spindle and in a sense cover the inner side of the rotor.
![]() Join Date: Dec 2003
Are you talking about the caliper mounting brackets?
Those are them actually. Guess I had the name wrong.
Happy to be here
![]() Join Date: Mar 2000
No, you had it right, they are dust shields. I don't think you want to mount your caliper to them.
What souce have you tried that was so pricey?
STILL PLAYS WITH TRUX
I'd get them from the junk yard if ya got a U PULL IT or something like that go there you will probably get both for les than 20 bux!
#8 | |
I know those may serve double duty as an inside dust shield but they are definitely very thick (1/8?) and are held on by 6 studs to the knuckle and the cut out and two bolt holes there are for the caliper. Last edited by blink32; 11-07-2008 at 12:56 PM. |
Exactly what I'm looking for. The actual dust shield part is all rotted, but caliper mount is fine.
Crazy
I agree with you blink, the calipers do mount to them, I would even offer a picture, but I happened to stick my tires back on last night. They are in fact pretty thick, I had my truck sitting down on the ground on them for a couple weeks until I stuck the tires on. Made it lasier to lower to lift the cab back on. Good luck finding them 454, I would also suggest a junk yard/u pull it of some sort. LMC only carries the 2wd ones from what I see.
77 SB Stepside in a bunch of pieces scattered around the garage. Last edited by tgh117; 11-07-2008 at 06:19 PM. |
Happy to be here
You are correct. I failed to see the 4WD part of his post. My bad...
