Old 11-08-2008, 06:21 PM   #26
jaros44sr
jaros44sr's Avatar
Re: HOW TO: One piece floor pan install
Originally Posted by jlaird View Post
The floor will be in this weekend. Unfortunately, i am having some problems with the fit of the floor flange at the firewall, particularly at the tranny hump. Theres about a 1/2 gap at the hump. Its too large to hammer. I'm going to have to cut it out and make a new piece. It sucks to have to cut that new floor, but its got to be done. I was thinking about the other people that documented the floor install on this board that didn't have this problem, but there might be a reason for that. msgross has a high hump so he didn't have to match the hump up with the firewall. The other, Tri-Pro, used their new firewall replacement, so again, didn't match up a stock firewall hump to the floor.
Here is the gap:
IIRC,I also had a 1/2" - 3/4" gap, I jacked the hump down in the center, using the bracing as a jack point, with pcs. of 2x4's, and using large C clamps to move it where I wanted it. Start in the center and work the metal into the area you want it. I wouldn't cut it yet, until you have exhausted all other options. I did have a problem in the area you are referring to, but I was able to move it into a workable solution
Here's some pics
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-08-2008, 10:52 PM   #27
jlaird
jlaird's Avatar
jaros44sr, do you think I should weld the floor in when the cab is resting on its floor or could I do it when the cab is on its back like in my pics, or doesn't it matter?
And WOW, your gap was way worse than mine. I can't believe you closed that up! Nice job. I also can't believe that that gap even existed in the first place being both the floor and the firewall are both new replacements from the same manufacturer.
jlaird is offline   Reply With Quote
Old 11-08-2008, 11:55 PM   #28
jaros44sr
jaros44sr's Avatar
Well, that the great thing about metal, you can move it where ever you want. Sometimes it looks really awful until you work with it alittle, then it bends into place. I would still rather work with new metal then try and patch up a rusty floor...Tri-Pro's parts are the best that I've seen, and I've been doing this for quite awhile...
I don't think it really matters which way the cab is laying, you can move it around to get at all the welds
I'll keep watchin'
SAFETY FIRST
AS usual, off topic
Jim
Old 11-09-2008, 10:23 AM   #29
jlaird
jlaird's Avatar
Overall, I really like this one-piece floor, I just needed a small amount of tweaking at the firewall flange. For some reason, the last couple of inches of the flange angled down which didn't match my firewall flange which is completely straight across. Instead of forcing it into place(it wouldnt of fit as nice), I made a pie cut and will put a little patch in. No biggie. Here are before and after pics and the area at the firewall it should match up to, then installed and tacked.
before:
after:
installed:
tacked:
here are the areas to be welded cleaned and sprayed with weld thru.
I also put the cab on the floor to insure it was on a solid, flex-free surface.
Old 11-09-2008, 10:24 AM   #30
jlaird
jlaird's Avatar
and here is the MONEY SHOT!
Old 11-09-2008, 10:36 AM   #31
rob32472
I am about to do this install how would you rate this on a scal of one to ten and since i will have to do a pillars and b pillars would it be better to do those first so i would have a way to bolt the cab in for the fit at fire wall. Any tips would be appreciated. BTW this is a great thread love the pics
rob32472 is offline   Reply With Quote
Old 11-09-2008, 11:03 AM   #32
jaros44sr
jaros44sr's Avatar
Nice work J, yeah for some reason the flange on the floorboard is like that, I just straitened the flange out and rebent it to fit, but your method looks like it worked as well
Rob, it would be hard to gauge your talents, but I think it is far easier then trying to fit up a bunch of patch panels...either way on your a and b post patches, but having the floor in place may make it easier...jmho
SAFETY FIRST
AS usual, off topic
Jim
Old 11-09-2008, 11:22 AM   #33
msgross
msgross's Avatar
I am doing my pillars last, but I still had part of the A-pillar in place to insure proper alignment. I haven't done any other patches but found that this install was pretty straight forward. You need some welding skill but not that much (i'm proof!).
1. Take a lot of measurements and don't get in a hurry...
2. Have the room to prop your cab on it's back without doing any extra damage..
3. Put in a lot of support to insure that things line up in the end
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-09-2008, 02:42 PM   #34
msgross
msgross's Avatar
looks good, I just got home from work and could see the pics, I don't remember my outer edge being hard to fit, one side was gone in the firewall so just made the patch to fit that curve...
The Garage:
Old 11-11-2008, 07:20 PM   #35
pickup6772
pickup6772's Avatar
WoW!!!! Just plain WOW. Please keep us posted, as I'm from NY, too. Does anybody know if anyone make a panel to replace the cowl?? I looked under my dash, and saw stars/swisscheese. With what I don't see for a good replacement cab up here, I might try to fix mine.
Mike
MIKE
'67 C/10 2WD LWB
'89 MERCURY GRAND MARQUIS LS
COUNTRY TILL THE DAY I DIE
pickup6772 is offline   Reply With Quote
Old 01-14-2009, 01:23 PM   #36
bama51
Question Re: HOW TO: One piece floor pan install
Do you have to remove the cab to do this or is it possible to do it while still sitting on the frame? Sorry, but I'm a newbie at this bodywork stuff, so be gentle with the comments.
bama51 is offline   Reply With Quote
Old 01-14-2009, 04:09 PM   #37
OLDIRON69
Yes, if doing the entire floor pan you would need to remove the cab from the frame.
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 01-14-2009, 04:38 PM   #38
ebfabman
Here is one I'm doing for a member here. Its getting a firewall too.
ebfabman is offline   Reply With Quote
Old 01-14-2009, 07:21 PM   #39
BlueJeep
BlueJeep's Avatar
Ooooh, more pics and details of what you're doing to the "scalped" cab, please.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 01-14-2009, 07:25 PM   #40
rob32472
check out project cod fish to get the details
Old 01-14-2009, 08:32 PM   #41
msgross
msgross's Avatar
are you doing a video on it? I could have used that... any details on your vent area rebuild?
The Garage:
Old 01-14-2009, 08:52 PM   #42
rob32472
We are going to do away with the vents this area will be flat with no boxes keep posted to the project for further details
Old 01-25-2009, 05:23 PM   #43
3quartertime
My Mistress the Sea
3quartertime's Avatar
+1... This is a job I'm interested in also. One of the DVD's would be way cool...
,,,they'd look alot better as beer cans...
'71 K20 350/350 Rusty but trusty... gone
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
'95 C3500 6.5L Dually love this one!...
3quartertime is offline   Reply With Quote
Old 01-25-2009, 10:58 PM   #44
thelonerife
thelonerife's Avatar
nice work. a lot of people need to see how this done
thelonerife is offline   Reply With Quote
Old 01-26-2009, 09:02 AM   #45
cobrajet21
cobrajet21's Avatar
This is useful. should be put in FAQ area.
cobrajet21 is offline   Reply With Quote
Old 07-07-2014, 10:57 AM   #46
DD1
I realize it's been a few years since anyone has commented on this post, however it has inspired me to replace the floor pan in my cab. I am almost finished bracing it, and would appreciate anyone's opinion on whether it is braced enough.
I have done everything except the final door bracing. I want to have the access to the inside before I finish it. I also added some cross beams to attach the lower bracings together.
I'll post an updated pic later, but here is the link to the last page of my thread where you can see the initial bracing pics in the final post.
Thanks!
http://67-72chevytrucks.com/vboard/s...=502964&page=8
___________________________________________
Darien
1971 C10 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=502964
DD1 is offline   Reply With Quote
Old 07-07-2014, 05:06 PM   #47
jlaird
jlaird's Avatar
I think you need a cross or diagonal brace someplace (one that goes from driver side to passenger side.) After that, you should be good. There is only so much wiggle room you will have anyway once you get the floor in there.
Old 07-07-2014, 05:24 PM   #48
DD1
Thanks. I will add that to the bracing. I'll post a final pic when I am done. I am bracing it up before I order the floor plan as I don't need to have something that big lying around until I get to it. Pretty motivated at this point though.
I appreciate the feedback and help.
Thanks!
Darien
1971 C10 LWB
Old 07-07-2014, 08:43 PM   #49
DD1
Okay, I think I am done with the braces. Please check out the last post in my thread and let me know what you think. Thanks!
Darien
1971 C10 LWB
Old 07-08-2014, 05:01 PM   #50
mooseknuckles
mooseknuckles's Avatar
glad someone brought this thread back. I'll be going this route as well, my rockers, cab corners, and cab mount area is shot! this seems way easier than piecing it all together the old school way.
mooseknuckles is offline   Reply With Quote
