Old 11-11-2008, 08:14 PM   #1
gary2232
Tire Sizes
Ok I know you should not put two different size tires on the same axel. But while in four wheel drive will it be ok to have a pair of 31x 10.5x15 on front and 32x10.5x15 on rear. The only reason this would happen is if I needed to use as a spare. Not the smartest thing but in a emergency will it cause any damage to transfer case or axels????
gary2232 is offline   Reply With Quote
Old 11-11-2008, 09:08 PM   #2
84lwb
84lwb's Avatar
Re: Tire Sizes
Not in 4wd.It could blow the gears out of the front or screw up the driveshaft,not sure about the driveshaft part maybe someone will chime in on that one but the gears i'm sure about.If you run it in 2wd with the hubs unlocked you should be ok.
84lwb is offline   Reply With Quote
Old 11-11-2008, 09:13 PM   #3
desertrat
desertrat's Avatar
Re: Tire Sizes
but more importantly, it looks funny and people will not think you are cool
desertrat is offline   Reply With Quote
Old 11-11-2008, 10:06 PM   #4
gary2232
Re: Tire Sizes
Yes I know kinda stupid but dont have a spare yet and want to do some wheeling. Thank for the info guys.
Old 11-12-2008, 03:52 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Re: Tire Sizes
I don't recommend it man. Its not good on the truck!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 11-14-2008, 03:25 PM   #6
1969K10
1969K10's Avatar
Re: Tire Sizes
will it get you home in a bad spot, yes. but you don't want to drive it like that any more than you have to.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
