Changing from low hump to high hump?
I have a 3/4 ton 70 GMC 4x4 4 speed that I will be using the frame and running gear from. I will be putting my 72 1/2 ton automatic cab on it. What do I do to make it fit?
Thanks in advance.
72 Super Cheyenne lwb 4X4 Ocra / White ![]() 88 Chevy 1 ton Dumptruck ![]() 88 Chevy 1ton Flat bed 4X4 white ![]() |
Re: Changing from low hump to high hump?
If you still have the 70 cab, just the sheet metal that you need out of it..
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
its all about the +6 inches
yep, the high hump bolts in/out of the old cab.
Toss it in onto the floor of the new cab, trace it, cut a hole one inche smaller than the traced shape, drill holes, bolt it in place with some seam sealer or good silicone (the right stuff by permitex) and call it a day. |
I need to do the exact opposite! I dont have an automatic cab layin around to cut the floor out of tho...
6>8 Plugless........
![]() Join Date: Sep 2007
Can anyone tell me if the 2wd 4 speed humps are the same heighth as the 4x4 4 speed humps? Thanks Ryan.
#6 | |
I have an automatic cab...just trying to see how I can cut mine out and still bolt in the high hump. Is the high hump wider? Last edited by Longhorn Man; 11-11-2008 at 11:35 PM. Reason: WTS post |
All high humps are the same size. So if you locate a big block autmomatic hump with no holes, then it'll be the same height as any other high hump with hols in it for shifters.
Just a note - the high humps with shifter holes have 3 different locations for the holes. Don't ask me how I know.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
interesting... The truck I bought is a bigblock auto and I believe it is a small hump. It does not bolt in, it is a solid floor piece.
I have also heard that 2wd big block/auto trucks had high hump trans covers.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB 1967 Custom Short Fleet - 327/4spd |
Texas Big Wig
Here is what I did on my truck Killer
![]() ![]() ![]() ![]() ![]() Last edited by Spray-Bomb; 11-12-2008 at 12:24 PM. |
That looks like a very clean install. Nice work!
Very nice! My Longhorn was a BBC truck with a 4 speed and it has a high hump.
There's been a handfull of trucks that have popped up here and there that were factory big block/autos with a low hump... but they were supposed to get high hump. The only big block that was supposed to get the low hump is a big block with a 3 sppedmanual... not a common combination.
#15 |
Thanks for the info. I am sure I will have more questions as this is my first body swap.
#16 |
Still livin the "dream" in '54
I just plaz'ed my low hump out and welded in the new one where it bolts up and seam sealed it really good.
I had custom carpet put in so I didn't have to worry about my old stuff fitting. Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
#17 |
upgrading to an older model
I switched from a I6 - 3 OTT combo to 307 - 700R4 combo. For some reason the tranny hit the low hump and wouldn't fit (wrong mounts, moved mounts, too tall tranny...whatever) so a sawzall and a $18.00 Highhump off ebay and problem solved. its not "bolted" in yet but it fits great...My (and probably one you will have if your going from low to high) question is how to attach and what kind of sealer if any. I'm thinking about using a bead of silicone and short self-tapping screws since there are no previous holes in the cab floor. Any suggestions?
68 stepside, short-box, multi-colored (for now) ![]() ![]() ![]() |
