Old 11-12-2008, 10:47 PM   #1
my67chevytruck
Under Construction
my67chevytruck's Avatar
lower control arm install ?
hello, after we did the 72 crossmember swap into the 67 , we blew it apart to rebuild, and install ece drop spindles. The question i have is how do you center the lca on the crossmember, i had rough measurements from the ubolts to the lca front and back on driver and passenger side but these were accidentally thrown away when we cleaned the garage. i have the lca's loosely installed, do i go ahead and install the spindle loosely and let it dictate the centerpoint via the balljoint shaft? the tighten the lca and install the spring and spindle completely? Thanks for any suggestions.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-12-2008, 11:10 PM   #2
jlaird
jlaird's Avatar
Re: lower control arm install ?
as far as i know, the lca's can only go on one way. Threre is a dimple in shaft that lines up with a nipple on the crossmember.
jlaird is offline   Reply With Quote
Old 11-12-2008, 11:24 PM   #3
texastrendz
if you are talking about the threaded cups onto the shaft, well, i am having the same problem. no one on this forum could answer that question. what i did is counted the turns on both sides. started it on the threads on each end and did a full turn on each end. it came out pretty much centered. have not taken it to the alignment shop yet. you can still adjust the top for the caster if it is a little off.
texastrendz is offline   Reply With Quote
Old 11-12-2008, 11:42 PM   #4
my67chevytruck
Under Construction
Ok Thanks for the info Guys. we overlooked the dimples at first but i noticed it when i crawled under the frame. also noticed it was tweaked a little
like a po hit something, i straightened it best i could and touched it up with chasis black.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 11-12-2008, 11:43 PM   #5
jlaird
jlaird's Avatar
I just centered mine. I also brought my control arm to an alignment shop because I was wondering the same thing, so I wanted to ask them. The guy said if he were to align the truck, he wouldnt use the lca threaded shaft as a way to align. I had thought it was used in alignment. Maybe the guy didn't know what he was talking about, but he has been in business for decades.
Old 11-12-2008, 11:54 PM   #6
my67chevytruck
Under Construction
i thought it was used for alignment as well. we centered the shaft as best we could it's still looks off, but i will have it checked at the alignment shop before it hits the road.
keep Truckin.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
