11-15-2008, 10:47 PM | #1 |
ls swap
hello just wantin to know what vehical years i can get the 5.3 and the 6.0 from thanks
11-16-2008, 12:17 AM | #2 |
Re: ls swap
I'm not an expert on them, but I have a 2004 in the garage, and have been researching the swap, they started using them in 1999, but there are different versions them in the newer years, ie flex fuel, active cylinder management etc. And the Painless Wiring Kits for the fuel injection system go through 2004. The carb setup from MSD/Edelbrock may work on some of the newers ones. Also, if you go EFI you will need to get the computer repogrammed as well.
Kyle |
11-16-2008, 10:06 AM | #3 |
Re: ls swap
If you are going with a 6.0 stay away from the 99 model. It had cast iron heads that didn't perform quite as well, plus they add uneeded weight. Also the crank flange spacing is different. Jim
11-16-2008, 10:47 AM | #4 |
Re: ls swap
all the reading i have done says to stay 03 or before, after that the changed to drive by wire, which is not horrible but you then have to mount a gas pedal from the newer model truck as well to get the electric signal to cpu. I am looking at doing a 6.0l swap myself
11-16-2008, 01:59 PM | #5 |
Re: ls swap
I'm using drive by wire. The benefit of it is it's easy to add cruise control....basically run a few wires from cruise control turn signal lever.
11-16-2008, 02:09 PM | #6 |
Truck and auto performance nut
Re: ls swap
You can always go with a carb and a front mount dizzy...or use a carb and a GM, FAST, MSD or other LS controller for the spark.
How about one of the new LSX sportsman block based LSX's coming out soon? LSX376 — Available Soon GM Performance Parts takes the LSX Bowtie block and combines it with the LS3’s L92-style heads to create the LSX376 crate engine. This engine will be delivered without an intake manifold (and other accessories), but can be fitted with either a carburetor or production-style injection system to make it suitable for your street rod, ’57 Chevy or ’71 Camaro....or '67-'72 truck! Specifications: Part Number: 19171049 Cylinder Heads (P/N 12615879): Aluminum L92 style port; “as cast” Engine Type: LSX Series Gen IV small-block V-8 with 68cc chambers Displacement (cu in): 376 (6.2L) Valve Size (in): 2.16 intake / 1.59 exhaust Bore x Stroke (in): 4.06 x 3.62 (103.25 x 92 mm) Compression ratio: 10.7:1 Block (P/N 19243171): LSX cast-iron with 6-bolt Rocker Arms (P/N 12569167 int): Investment-cast, roll trunnion cross-bolted main caps Rocker Arms (P/N 10214664 exh): Investment-cast, roll trunnion Crankshaft (P/N 12597569): Nodular iron Rocker Arm Ratio: 1.7:1 Connecting Rods (P/N 12607475): Powdered metal Recommended Fuel: 92 octane Pistons (P/N 12166957): Forged aluminum Maximum Recommended RPM: 6600 Camshaft Type (P/N 12603844): Hydraulic roller Reluctor Wheel: 58X Valve Lift (in): 0.551" intake / 0.522" exhaust Balanced: Internal Camshaft Duration (@0.050 in): 204° intake / 211° exhaust LSX454 — Available Soon An engine with 454 cid will always recall legendary Chevys, and that tradition will continue with the all-new LSX454 crate engine. Based on the LSX Bowtie block, the new LSX454 will be delivered in Deluxe form, so you’ll get everything you need from the carburetor to the water pump, plus “LSX454” engraved valve cover logos. Specifications: Part Number: 19170112 Cylinder Heads (P/N 19201806): Aluminum LSX-LS7 port; Engine Type: LSX Series Gen IV small-block V-8 "as cast" with 70cc chambers Displacement (cu in): 454 (7.4L) Valve Size (in): 2.20 intake / 1.61 exhaust Bore x Stroke (in): 4.185 x 4.125 (106.3 x 104.8 mm) Compression ratio: 11.0:1 Block (P/N 19243172): LSX cast-iron with 6-bolt Rocker Arms (P/N 12579615 int): Investment-cast, roll trunnion cross-bolted main caps Rocker Arms (P/N 12579617 exh): Investment-cast, roll trunnion Crankshaft (P/N 19170391): 4340 forged steel Rocker Arm Ratio: 1.8:1 Connecting Rods (P/N 19166964): 4340 forged steel Recommended Fuel: 92 octane Pistons (P/N 19166958): Forged aluminum Maximum Recommended RPM: 6500 Camshaft Type (P/N 19166972): Hydraulic roller Reluctor Wheel: 58X Valve Lift (in): 0.635" intake / 0.635” exhaust Balanced: Internal Camshaft Duration (@0.050 in): 236° intake / 246° exhaust
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-17-2008, 08:55 PM | #7 | |
Re: ls swap
It also looks cleaner IMO, no throttle cable on the firewall.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
11-17-2008, 11:30 PM | #8 |
Re: ls swap
I agree with ford assassin. It was easier to install the DBW unit than to mess with the cable. It's also really easy to floor it....hehe
11-17-2008, 11:38 PM | #9 | |
Re: ls swap
11-19-2008, 12:05 PM | #10 |
Re: ls swap
how difficult is this swap
11-19-2008, 03:10 PM | #11 |
Re: ls swap
That's a loaded question..........................
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
