11-17-2008, 10:04 PM | #1 |
Nothing to see here.....
Dead Coil??
I think I killed my coil. yesterday I "attempted" to install my factory tach cluster, but found that the tach was grounding out on the mounting cup. (the tach harness runs to the "ignition unfused" and the ground runs to the coil negative post)
question. can you kill a coil when grounded out??? by the way, I'm running the good old point ignition system.....
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 11-17-2008 at 10:21 PM. |
11-17-2008, 11:32 PM | #2 |
Re: Dead Coil??
I don't know but ttt for you.
11-18-2008, 12:08 AM | #3 |
Re: Dead Coil??
Don't know either I know on my MG I had the coil go out for some of the stupidest reasons though never had much luck with old style coils. At least heres another TTT for ya
11-18-2008, 12:39 AM | #4 |
Between Trucks...
Re: Dead Coil??
Sounds like a good time to upgrade to an HEI. TTT
Beat it to fit, Paint it to match... Last edited by Sinister; 11-18-2008 at 12:39 AM. |
11-18-2008, 01:32 AM | #5 |
Re: Dead Coil??
You shouldn't have hurt the coil as it is actually grounded every time the points close. Unless it overheated to the point that it was damaged.
A lot of manuals have instructions on how to test a coil with an ohm meter. I have an ancient coil tester that actually works quite well to test the point style coils an is quite simple. You might find a shop that has something similar that they can test the coil with. |
