Old 11-18-2008, 09:39 PM   #1
Green Machine
Green Machine's Avatar
I ain't got no traction satisfaction !!!
Basicly stock 1971 C20 LWB body and chassis, turbo 350, 2000 stall, 3.54 Dana posi an a healthy 383. I know I need more rear tire, but want to retain the sleeper look. Have 245/75 R16 8 bolt front and back now. I can get a pair of painted 8 inch 8 bolt wheels that take the stock hubcaps and go to a 265/70 R16 tire. Or maybe a little more, any suggestions ? I want to stay about same tire height.
The truck pretty much spins both tires all the way through first gear and just catches traction just before it shifts at about 5500 rpm. Would some half ton rear springs help, maybe some half ton front springs too ? Need to get some weight transfer going on or something. I can still beat most everyone out of the hole while spinning the tires, but if I could hook up, that would be much better !!! Any thoughts ? Had it to the track twice this summer, runs about 9.50 in the 1/8, pretty good I think for a 4200 lb truck and no traction.
Any thoughts appreciated - Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-18-2008, 09:55 PM   #2
6872xtc
6872xtc's Avatar
Re: I ain't got no traction satisfaction !!!
My experience is limited, but mine gained traction by letting air pressure down in the rear. I'm not sure how well your tires will respond though. I started at 20 psi and dropped 2lb after each run, watching 60ft times and ET's equally.
6872xtc is offline   Reply With Quote
Old 11-18-2008, 10:55 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
trust me, 275's will still light up. mine do.
try a 3" drop or play with the track bar position on the X-member.
another place of concern is the tires. granted dropping pressure will help but I fear that 16" truck tires dont have much bite.
you could also get highly involved with timing and fuel curves. drop back some at lower revs.
68C15 is offline   Reply With Quote
Old 11-19-2008, 12:20 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the fact of the matter is, launching on street radials is always gonna be a PITA. You'll gain more by learning to launch instead of looking for other street tires that'll do the same thing.
Now, if you can have some dedicated drag tires for the rear, that you chainge out at the track... then after a good burnout, you'll be hookin up good.
Old 11-19-2008, 01:46 AM   #5
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
Do you have a front anti-sway bar? If so, you'll want to remove it as it prevents the front end from lifting and shifting weight to the back.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 11-19-2008, 07:54 AM   #6
MotorSeven
Restoration Desperation
MotorSeven's Avatar
Have you tried just putting some weight right over the axle? 80lb bags of sand work great & won't slid around.
RD
MotorSeven is offline   Reply With Quote
