Old 11-18-2008, 10:30 PM   #1
jlaird
jlaird's Avatar
engine location
What are the pros and cons(and reasoning) of having the engine in the forward motor mount location vs. rear? Being bagged, any reason for one over the other? Do people have issues with an HEI hitting the firewall?
jlaird is offline   Reply With Quote
Old 11-18-2008, 11:21 PM   #2
Shane
Shane's Avatar
Re: engine location
If I remember correctly, the V8's came in the front holes from the factory and the I-6's came in the rear holes.
I'v heard the factory moved the V8 further forward due to handling & brake bias differences caused by the engine being heavier.
Shane is offline   Reply With Quote
Old 11-19-2008, 08:10 AM   #3
jlaird
jlaird's Avatar
Re: engine location
Oh good. I didn't know that. Thanks for the info.
Old 11-19-2008, 01:00 PM   #4
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: engine location
I moved my engine as far back as possible & made my own holes
It was a lot more work, but it balances the trucks weight out more
I also had to put a high hump in it for the trans to fit
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-19-2008, 01:06 PM   #5
scotts62
One day...
scotts62's Avatar
Re: engine location
They look better moved back i think, then they dont have that big gap between the distributor and firewall
Scott
93 crew cab build
Project 62
Old 11-19-2008, 02:34 PM   #6
Slammed67
Progress = 0%
Slammed67's Avatar
Re: engine location
I moved mine back and lowered the front mounts slightly to give me more firewall/distributor clearance. I just think it looks better in the rear position.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 11-19-2008, 08:41 PM   #7
protrash64
Resistance is Futile
protrash64's Avatar
Re: engine location
Most of the 60-66's I see have the engine mounted in the rear position which I believe is factory for these years. I pulled mine forward for easier distributor clearance and if you drop a beer it will fall all the way to the floor!! I was changing to an aftermarket trans x-member at the same time so it was the same amount of work. I have not had any issues in the front position.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-19-2008, 10:01 PM   #8
jlaird
jlaird's Avatar
Re: engine location
I thought I had read about HEI's hitting the firewall when the engine is in the rear position??
Old 11-19-2008, 10:38 PM   #9
protrash64
protrash64's Avatar
Re: engine location
Hei still fits. my 'burb has the engine in the rear position. Again, its a 64 and it may be different than the 67-72. The frames are generally the same as far as I know.
Old 11-20-2008, 12:49 AM   #10
crazy longhorn
Fabricate till you "puke"
Re: engine location
HEI is tight, but does fit in rear position (67-72). My 383 is set in on I6 stands, & I have no issues with the distibutor......& the truck is body dropped 1 1/2" to boot. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
