Old 11-19-2008, 10:58 AM   #1
jmedero
jmedero's Avatar
super budget gas tank...
Ok I got a sweet deal on a 66 lwb with a bed of parts. Have been doing the body work and stuff like that. I want to replace the brand new tank from in the cab to out of the cab unit. The plan is a super TIGHT budget on this truck, but trick it out as much as I can. The dare was to build it for $6k or less and make it lay frame. So every penny counts. Any ideas whats a budget minded way to do this tank conversion? I have checked out the tank kits and it would be like $350 for everything to make it work.... just want to make sure thats the cheapest way. Did I mention the $6k was paint and wheels also!! I love a good chanllenge
jmedero is offline   Reply With Quote
Old 11-19-2008, 11:23 AM   #2
scotts62
One day...
scotts62's Avatar
Re: super budget gas tank...
There is another tank that you can get for the back thats around $200 with sending unit, i cant remember the link though, im sure one of the other guys will post it up real soon though.
Do a search in the forum for fuel tanks there is all sorts of different ways the guys have done theirs.
Scott
93 crew cab build
Project 62
Old 11-19-2008, 01:08 PM   #3
kissingbug1978
This will save you a buck 50.
http://www.lmctruck.com/ICATALOG/CBE/full.aspx?Page=67
kissingbug1978 is offline   Reply With Quote
Old 11-19-2008, 02:52 PM   #4
kizer
Its Deja Vu time again
kizer's Avatar
Thats where I saw that. I saw another that was stainless or whatever and they wanted around $750.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 11-19-2008, 04:59 PM   #5
scotts62
One day...
scotts62's Avatar
yep thats the one i was thinking of too.
Scott
93 crew cab build
Project 62
Old 11-20-2008, 07:49 AM   #6
HotRodYJ
HotRodYJ's Avatar
The cheapest way is to use a tank from another vehicle and not buy new. Adapt it and make it work. I'll probably use a tank from and Astro van or a Jeep tank that I've already got laying around. Cost = priceless
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 11-20-2008, 12:53 PM   #7
kizer
kizer's Avatar
Jeep Wrangler looks pretty close to the same shape as that LMC truck catalog, 19gallon and made out of that poly/plastic stuff. Heck grab a stocker and I'm sure you could grab the 1/8 steel box they call a armor which happens to have the holes for hanging it.
Heres what an aftermarket skid looks like, but you can see the square holes in the rear that that straps use. I have a 2000 wrangler if anybody needs measurements I could take them.
Heres how it was installed if anybody wants to bother looking at it as well it shows pictures of the Jeep tank.
http://www.jeepaholics.com/feature/k...id/default.htm
TJ, the round headlight one fills from the drivers side, YJ square headlights fills from the back, however I'm sure you could remove the clamps and add new hoses.
Old 11-20-2008, 01:21 PM   #8
HotRodYJ
HotRodYJ's Avatar
Most of the conversions with a factory style tank instead of a fuel cell just use a stock Blazer fuel tank.
Old 11-20-2008, 01:31 PM   #9
502tripower
502tripower's Avatar
Here is what I did. Tank is out of a late 70's-early 80's 1/2 ton Chevy Van. Welded a 3X4 piece of angel to the end of the bed rails and drilled for the hangers. Also had to trim the lower edge of the upper X-member slightly and the one cross sill. Hole sawed threw the frame for the fuel fill and used a 88'-98' Chev Pickup gas door. I think I paid 35.00 for the tank fuel fill neck and door.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 11-20-2008, 01:39 PM   #10
502tripower
Couple more pics...
98' FXD
2002 2500HD
Old 11-20-2008, 04:58 PM   #11
kizer
kizer's Avatar
502tripower,
From the looks of it you cant see your tank at all with the bumper mounted. Any idea if you would see it if you had just a roll pan attached or do you think it would be hidden?
Old 11-20-2008, 05:02 PM   #12
502tripower
Originally Posted by kizer View Post
502tripower,
The roll pan does hide the tank completely.
98' FXD
2002 2500HD
Old 11-20-2008, 06:23 PM   #13
jmedero
jmedero's Avatar
502 I like that set up. Looks clean.
thanks for the ideas guys.
Old 11-20-2008, 06:43 PM   #14
rickf
rickf's Avatar
502, Is that purple heart bed wood I see?
rickf is offline   Reply With Quote
Old 11-20-2008, 06:56 PM   #15
slepysal
slepysal's Avatar
Maybe this will work for you ....
http://www.67-72chevytrucks.com/vboa...d.php?t=234732
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 11-21-2008, 12:31 PM   #16
502tripower
Yes it is...
98' FXD
2002 2500HD
Old 11-21-2008, 01:19 PM   #17
scotts62
One day...
scotts62's Avatar
I like that! looks good 502
Scott
93 crew cab build
Project 62
Old 11-21-2008, 02:31 PM   #18
terrellautosports
New Member
terrellautosports's Avatar
summit racing has some to choose from. i might go with this setup if i don't build my own.
http://store.summitracing.com/partde...5&autoview=sku
1968 SWB Project. Soon to Start Build Thread
terrellautosports is offline   Reply With Quote
Old 11-30-2008, 02:07 AM   #19
Tomsriv
Tomsriv's Avatar
FYI, The "Blazer" tank which LMC and others sell is also found in the more common Suburban.
'65 Chevy shortbed stepside.
Tomsriv is offline   Reply With Quote
Old 11-30-2008, 02:39 AM   #20
1961chevy
1961chevy's Avatar
I used a 66 mustang tank, the cost was around $100 with sending unit
1961chevy is offline   Reply With Quote
Old 11-30-2008, 07:46 AM   #21
nhtc33d
Does the sending unit work with the stock fuel gauge?
nhtc33d is offline   Reply With Quote
Old 12-01-2008, 12:23 AM   #22
1961chevy
1961chevy's Avatar
not shure if the sending unit works, because the tank is just mocked up in the frame as of now
Old 12-01-2008, 04:49 PM   #23
slepysal
slepysal's Avatar
How about some pics
Old 12-01-2008, 06:48 PM   #24
1961chevy
1961chevy's Avatar
man i wish i could, ill try to borrow a camera, by the way i have a custom back half but i did have it on the stock frame before i built the backhalf, the spout came up through the floor
Old 12-01-2008, 07:20 PM   #25
LILRED66
LILRED66's Avatar
1961chevy:
Welcome to the boards from Kansas City, KS.
jmedero:
Keep us posted with your progress.
LILRED66 is offline   Reply With Quote
