Old 11-19-2008, 07:53 PM   #1
jephs422
Scotts 67-72 firewall
Here's some installed pictures of the 67-72 Chevy Truck firewalls. I have some fab shots, but for the life of me I can't find them right now. I'll post those ones tonight as soon as I can find them
This firewall retails at $699 for the firewall and kick panels
This one is set up to add 4 inches of foot room, but you can get them stock also.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
Old 11-19-2008, 07:55 PM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: Scotts 67-72 firewall
Cool! I need that leg room at 6' 3". Looks cool too!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-19-2008, 08:02 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Nice! Any shots of the kick panels? What kind of bracing is there inside?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-19-2008, 08:17 PM   #4
Painter D
Painter D's Avatar
x2
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 11-19-2008, 08:22 PM   #5
BadgerTheFerret
Be nice, it was a work truck!
BadgerTheFerret's Avatar
Lookin' good!
BadgerTheFerret is offline   Reply With Quote
Old 11-19-2008, 08:40 PM   #6
8mpg
8mpg's Avatar
hope this doesnt sound rude... but $800 for flat sheet steel cut to shape? I know it has a couple bends..but it seems like something anyone can make with a air sheer and welder.
8mpg is offline   Reply With Quote
Old 11-19-2008, 08:52 PM   #7
jlaird
jlaird's Avatar
yeah, that was my first thought. 800 for sheetmetal, Jeph, whats up with that?!?
Seriously, jeph is a great guy. I just bought a frame mount brake assembly from him.
jlaird is offline   Reply With Quote
Old 11-19-2008, 08:58 PM   #8
Scottshotrods
not rude at all thankyou for bringing that up if you look at the firewall
you will notice it has a double rolled recess this is for the engine clearence
the recess has been fully welded and metal finish.The firewall comes with
new kick panels as well.The kick panels you weld these directly to the stock
floor pan.On thursday we will take some shots of the inside of the cab so
you can see how the firewall looks after it has been fully welded in.
Thankyou,
Justin
Scotts hotrods
Scottshotrods is offline   Reply With Quote
Old 11-19-2008, 09:04 PM   #9
8mpg
8mpg's Avatar
Sounds good man... The setup looks great, just thought it was pricey.
Old 11-20-2008, 12:26 PM   #10
jephs422
I was right about one thing...I did overprice it, LOL.
The price is actually $699.00 for the firewall and kick panels.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 11-20-2008, 12:31 PM   #11
50MOTORHEAD
50MOTORHEAD's Avatar
More foot-room is always welcome .These old trucks didn't seem that tight years ago. then you get the stock steering wheel pushed in your chest,,kinda tight-KB
50MOTORHEAD is offline   Reply With Quote
Old 11-20-2008, 01:26 PM   #12
jephs422
more pics as promised
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
Old 11-20-2008, 03:07 PM   #13
gringoloco
A guy with a truck
gringoloco's Avatar
- Is that a stock bolt-in tranny hump?
- How does the extended floor affect pedal placement with the under floor booster?
- Any internal bracing planned?
Thanks -Chris
-Chris
Old 11-20-2008, 03:49 PM   #14
Scottshotrods
Thanks -Chris
That is stock tranny hump but we made a new taller tunnel to give a little
more room for the tranny.On this truck in are shop it has a tube chassis
and it is full independent on air and lays out on 22's and the motor is a
l-s1 motor with a 4l80e tranny.The master booster on this truck is mounted
under the dash and the firewall was dropped down to add more leg room
for are customer and we have some bracing mounted to inside of the firewall
and we are going to be running the bracing downward to the floor area.We are going to be mounting some hinges on the firewall and these will tie into the firewall bracing so the sheetmetal will not have any flex.The factory hinges will not work,they run into the tires when it is layed out.For the brake
pedal we have a different brake pedal we make with are kits when somebody
wants one of are firewalls with more leg room.We also make another firewall
for these trucks that does not have any issues with the brake pedal.That firewall does not have any more leg room.Hopefully this answers your questions.
Thankyou,
Justin
Scotts Hotrods
Old 11-20-2008, 04:13 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That is pretty slick!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-20-2008, 04:37 PM   #16
Scottshotrods
Thankyou,Anything we can do for you let us know
Justin
Scotts hotorods
Old 11-20-2008, 07:32 PM   #17
gringoloco
A guy with a truck
gringoloco's Avatar
Thankyou,
Justin
Scotts Hotrods
It does. Thanks for the detailed response. Are you guys working on anything for inner fenders?
-Chris
Old 11-20-2008, 07:57 PM   #18
Scottshotrods
Glad you asked that, we are making some inner fender wells for the 67
that is in the shop.Like I was saying earlier it has 22's on the front now
and the truck lays out.The fender wells we are making will work with other
size wheels and tires.When we get closer on them we will post some pics.
Thankyou,
Justin
SCOTTS HOTRODS
Old 11-20-2008, 09:17 PM   #19
stunna
Thankyou,
SCOTTS HOTRODS
I can't wait to see these!!
stunna is offline   Reply With Quote
Old 11-20-2008, 09:19 PM   #20
stunna
Oh by the way the firewall looks real good!! I'm feelin that!
Old 11-20-2008, 09:27 PM   #21
69trk
69trk's Avatar
I would like to see those inner fender wells also. Mabey you can come up with some wider wheel tubs for the rear also.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 11-21-2008, 12:20 AM   #22
Rigo's 70 C10
Wow, you guys are really stepping up to the plate and giving us some great options! Subscribed.
Rigo's 70 C10 is offline   Reply With Quote
Old 11-21-2008, 01:13 AM   #23
Scottshotrods
we are going to be posting a few pics of are smooth wiper
cowl panel we make out of 16 ga sheetmetal that also retains the factory wipers,but give you a smooth look.
On friday in the shop we are going to be shaving the drip
rails on the 67 cab and we are also going to be filling in the factory rear roof seam.We will be posting some pictures
for you guys to look at.
JUSTIN
Scotts HOTRODS
Old 11-21-2008, 01:30 AM   #24
nuke1
nuke1's Avatar
great stuff to see, Justin, and Jeph. i am about to start on my truck next week now, so can not wait to get the booster from you guys, thanks and the guys at scotts are real good, best service in the industrry i have come across yet!!!
James
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 11-21-2008, 09:48 AM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
What are you doing for hood hinges?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
