Old 11-20-2008, 04:44 PM   #1
turbotank
turbotank's Avatar
strange thing hooked to brakes
Hey,I am swapping a 14 bolt from a parts truck I got to my suburban,and I crawled under the parts truck,looked over the axle,all good.Then I saw this thing with an arm and some kind of hydraulic servo(I guess) attached to the rearend.The brake line comes from the front into this thing,and then another brake line comes out and goes to the hubs.What is this?There isn't one on my suburban.
The general is always in charge
You guys did this to me!!!!!!!!!!!!!!!!!!!!
turbotank is offline   Reply With Quote
Old 11-20-2008, 05:04 PM   #2
skidder111
skidder111's Avatar
Re: strange thing hooked to brakes
I believe that is an adjuster which proportions the amount of braking depending on how much weight the truck is carrying. It is usually found on camper specials. It senses the amount of sag in the rear springs (ie) more weight, more sag. You probably don't need it in the Sub.
skidder111 is offline   Reply With Quote
Old 11-20-2008, 05:17 PM   #3
turbotank
turbotank's Avatar
Yeah,my parts truck is a camper special,so that would make since.Is it beneficial at all?
Old 11-20-2008, 06:26 PM   #4
skidder111
skidder111's Avatar
I would think that it is not necessary because (1) your Burb doesn't have it now, and (2) the Burb probably won't be carrying the weight that the truck did. Just my $0.02.
Old 11-20-2008, 08:01 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Load adjusting proportion valve.
You won't need it on the burb.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-20-2008, 08:25 PM   #6
vern350
like a rock
vern350's Avatar
My dad had a 87 3/4 ton 4x4 burb with one from factory.......
vern350 is offline   Reply With Quote
Old 11-20-2008, 09:26 PM   #7
turbotank
turbotank's Avatar
Hey,you never know how much weight I'll put in there,just gotta take the family to a buffet restaurant........
Will I be able to use the brake lines off the 10 bolt if I get rid of this joint?
Does anyone know of an all-inclusive rebuild kit for the 14 bolt?Mostly just want to replace seals.
