Old 11-21-2008, 05:05 PM   #1
69Rob
69Rob's Avatar
6 lug rotors?
I just bought a disk brake setup from a 81 chevy but i want to keep the lug pattern does any one know of any rotors that are available at a local auto store that i can interchange?
2009 dodge hemi custom paint
86 lwb bagged layin frame
73 2 door nova
54 bel air
69Rob is offline   Reply With Quote
Old 11-21-2008, 05:51 PM   #2
69Rob
69Rob's Avatar
Re: 6 lug rotors?
if i buy the rear end will it bolt up considering mine is a coil and the 81 is leaf?
73 2 door nova
54 bel air
Old 11-24-2008, 02:45 AM   #3
Captainfab
60-66 Nut
Re: 6 lug rotors?
The only ones that I know of that will fit those spindles are the aftermarket ones from CPP and a couple others. If you want to use off the shelf parts you'll have to do it this way.
http://www.67-72chevytrucks.com/vboa...ad.php?t=35042
This is what I'll be doing to my Burb when I get some time.
Old 11-24-2008, 02:51 AM   #4
Captainfab
60-66 Nut
Re: 6 lug rotors?
Assuming from your user name and your sig. that you have a '69, the '81 rear end will be 1.5" wider that the 12 bolt you currently have. Plus you'll have to cut off the leaf spring pads, weld on the correct ones for the trailing arms, and fab a bracket to connect your panhard bar to the rear end. Then there will be small issues like e-brake cables and possibly the need for a conversion U-joint.
