11-21-2008, 06:15 PM | #1 |
Blue 67
Ignition switch removal:
Hey guys:
How do you remove the ignition switch from dash? Is there a clip behind it or it just screws out of the dash? Thansk.
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
11-21-2008, 06:30 PM | #2 |
Re: Ignition switch removal:
11-21-2008, 06:31 PM | #3 |
You have to insert a paper clip, or small stiff piece of wire in the little hole by the key while the key is in the accessory position. Wiggle it and the lock portion should come out. Then just unscrew the front bezel piece, and will all come apart.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! |
11-21-2008, 06:33 PM | #4 |
Once you remove the ring (in the front) it will come out...The pain is getting it back together (all in reverse).
11-21-2008, 06:48 PM | #5 |
Blue 67
Thanks for the replies. My problem is the bezel on the dash is not coming off. Does it screw in or slide in?
11-21-2008, 07:13 PM | #6 |
I think the actual bezel itself unscrews. I think you have to remove whats inside of the bezel first though. If that makes sense.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
11-21-2008, 08:20 PM | #7 |
what if u have no key
11-21-2008, 11:41 PM | #8 |
The Older Generation
Take the passengers door lock out, take it to a locksmith and have him cut a key from the code stamped on it.... If the locks are original the key will fit the ignition.
LockDoc
11-22-2008, 12:27 AM | #9 |
its all about the +6 inches
and if that fails, you can drill out the ignition switch, or beat on it with a hammer and a large punch.
I've personally done the latter twice with no dash dammage.... but it CAN happen if you get stupid with the hammer... or if you have bad aim. |
11-22-2008, 12:34 AM | #10 |
Ya it has been so long since I took it apart like 10 years ago so no idea where the key is
11-22-2008, 01:33 PM | #11 | |
Man Im glad I logged on today...Im at work and my jet is broke so Im just sitting here wasting time! Im in the same situation....dont have the right key, so as soon as I get home Ill take the passenger door lock and see what happens.. Question though, why the passenger and not the driver??? Whats the difference?? THANKS!! |
11-22-2008, 02:13 PM | #12 |
Your jet?
11-22-2008, 05:42 PM | #13 |
Blue 67
Well, some hamering and drilling did it. I got some scratches on the dash but boy that was a pain. I had to cut the bezel. Although it was old and chipped but now I have to buy a new one. I even don't know if anybody sells them.
11-22-2008, 07:01 PM | #14 |
I'm a poor spectator
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
11-22-2008, 07:51 PM | #15 |
Most Classic Chev truck goodie vendors sell the bezel for the switch. The new switch and lock cylinder are still available through most parts houses although you will probably have to special order them.
Just a note from a guy who has been at this for a long time. I never throw a car key away if I junk out a rig or find one in a junk car or have one left that didn't go with a car I sold. That has saved my bacon more than once when I didn't have a key for a customers car or when the customer locked the car and left it in the way of everything going on. |
11-22-2008, 11:38 PM | #16 | |
LockDoc
11-23-2008, 12:21 AM | #17 |
hahaha
Im in the Air Force...Im a C5 Loadmaster... Thanks for the info...hopefully the passenger lock will work! As for the bezel ECE or LMC sell them....only thing is the spacer in the back isnt made anymore from what Im being told, so keep yours.... |
