Old 11-23-2008, 12:07 PM   #1
53burb
53burb's Avatar
'04 Suburban won't start
Guys,
I know this is going to sound vague, but I will tell you what I know so far. The Suburban is an '04 with 87,000 miles, 2WD, 5.3/4L60E. It ran fine when we parked it a couple of days ago. Last night, my wife went to start it, & it didn't start. Tried to start it today & no luck. It's not showing any errors on the message board. I pulled a spark plug & it is getting spark. I also checked for fuel at the Schrader valve. Fuel does come out, but does not come out under pressure. I don't have a gauge to test it, but shouldn't it being coming out at around 75psi?? Any suggestions and/or ideas??
Chris
53burb is offline   Reply With Quote
Old 11-23-2008, 12:14 PM   #2
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Re: '04 Suburban won't start
Try to start it with a little shot of ether, if it starts you'll know you got a fuel issue.
Can't help you with the p.s.i.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 11-23-2008, 12:37 PM   #3
53burb
53burb's Avatar
Thanks for the tip, I forgot I had starting fluid, but where would you try that on this engine for future reference?? Anyways, its definately a fuel pump issue. I hit the fuel tank near the pump about 10-15 times with a hammer & it started right up. So, I guess the fuel pump is going out, right??
Old 11-23-2008, 12:39 PM   #4
Underpowered
PSI should not be 75. upper 30's to low 40s is more what it takes.
as retodd said, shoot a little shot of ether int eh throttle body itsleft and see it it will hit.
when you turn the key on, can you hear teh fuel pump? the pump should run a few seconds whenever the key is turned from the off to on position. if you don't hear the pump. smack the bottom of the fuel tank a few time. sometimes this will jar the pump enough to allow it to run, but is a one shot wonder though as it usually will only work like that one or two times.
2003 Z71. 305/70-15 MT ATZ's wrapped around 16x10 AR diamondbacks. OBX long tube headers, Blackbear Tune, a few other bolt on goodies.
1995 Jeep ZJ aka "the Heep"
Underpowered is offline   Reply With Quote
Old 11-23-2008, 12:40 PM   #5
Underpowered
guess my other post was a little late lol. fuel pump for sure.
but to ether it, through the throttle body works fine.
Old 11-23-2008, 12:50 PM   #6
53burb
53burb's Avatar
Thanks, i was thinking thru the throttle body, but I didn't think it would make it down to the injectors. So you think it has a very limited time left on this pump?? It only has 87,000 miles on it & since we have had it at 82,000 miles, I don't think we have ran it with less than 1/4 to 1/3 tank of gas. That helps to keep the pump cool, right?? Maybe the PO ran it lower on a cosistent basis.
Old 11-23-2008, 12:55 PM   #7
Underpowered
it does not matter if the starting fluid actually makes it to the injectors. going through the TB t will follow the path of the incoming air.
and i would not trust that pump for long. different fuel systems work different ways. some systems the pump is cooled by the return fuel, so as long as excess fuel is going back into the tank the pump is beign cooled no matter how much fuel is actually in the tank itself. my silverado, has 135k on the original pump, and i run it down to 1/8 tank on a regular basis.
Old 11-23-2008, 01:01 PM   #8
53burb
53burb's Avatar
I replaced my pump in my '99 Chevy truck & it had about 100K on it at the time. I got the pump from NAPA, it was a GM/Delphi unit, which is what I wanted. I looked at NAPA online, it doesn't have a pump listed. Checker's has a Bosch unit with a 1 yr warranty for $850 & AutoZone has one listed for $300 from ???? with a 1 yr warranty. I guess I will call the dealer tomorrow. Any other suggestions on where to get it from??
Old 11-23-2008, 01:26 PM   #9
oomag12
Check the sending unit too. prob. not an issue an AZ. The PO on my 97 was from MI and the sending unit piping was corroded pretty bad, replaced it at the same time. I used the Carter unit for 236.00 at Advance
oomag12 is offline   Reply With Quote
Old 11-23-2008, 02:30 PM   #10
53burb
53burb's Avatar
Smile Re: '04 Suburban won't start
I replaced the fuel filter when we got the burb about 6-8 months ago......no corrosion.....it looks like a typical AZ truck....
Old 11-23-2008, 04:14 PM   #11
truckdude239
truckdude239's Avatar
i'll tell you after going though 5 pumps from advance auto i will only install a dealer pump from now on. get a good quality part
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-23-2008, 04:17 PM   #12
Underpowered
i thought that you could only get the complete sending unit, and not just the pump.
Old 11-23-2008, 04:27 PM   #13
oomag12
No, you can get 'just' the pump, Bosch, Carter, or a Master
Old 11-23-2008, 04:33 PM   #14
retodd7711
retodd7711's Avatar
I can't believe I forgot this.
When using ether---ALWAYS have a fire extinguisher ready.
If you have a no-start because of a jumped timing belt, a spark can jump back into the intake.
Learn from my mistakes, don't repeat them.
She can't cook
So forget her.
My old farm truck
Old 11-23-2008, 04:35 PM   #15
Underpowered
Keep cranking in the case of a a back fire through the carb/throttle body. the engine will suck the fire back down.
Old 11-23-2008, 04:39 PM   #16
oomag12
The Carter unit is made by Federal Mogul out of MI, so the jury is out on it so to speak on its longevity. They do have an OE line for GM. They built carbs since the model a days i think. I stay away from Bosch on GM products, got stuck with Bosch plugs and wires on an Oldsmobile with HEI distributorless ignition system few years back. Put GM plugs and wires(bought at the dealer) and corrected the dead miss.
Old 11-23-2008, 04:52 PM   #17
msgross
msgross's Avatar
Couldn't it be a clog or another issue within the fuel tank? Did you take the fuel cap off and try it? clogged vent line would yeild a pressure lock on the tank....
Just some ideas.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-24-2008, 01:11 AM   #18
53burb
53burb's Avatar
I haven't tried anything else. Since it has started, I have turned off & on a couple of times w/o any problems, but have only moved the Burb out of the driveway.
Old 11-24-2008, 03:13 AM   #19
dailydragger03
dailydragger03's Avatar
If the eighth digit of your vin is a T then the delphi unit from napa is probably a DFP FG0273. I can try to get some more info on tuesday when I go back to work.
03 ext cab stepside silverado bagged on 20's with some other cool stuff (daily driver)
1970 c10 short step just gettin started on it (project)
dailydragger03 is offline   Reply With Quote
Old 11-24-2008, 03:16 AM   #20
53burb
53burb's Avatar
thanks, i'll check it tomorrow....i do know that it is a "flex-fuel" system....
Old 11-24-2008, 12:37 PM   #21
53burb
53burb's Avatar
I just checked the VIN, it's a Z.
Old 11-24-2008, 07:32 PM   #22
53burb
53burb's Avatar
I just picked up P/N 88966963 from the dealer. They needed the last 8 digits of the VIN. NAPA couldn't get it. It was $350. I don't consider that too bad since a pump from Checker's was $300.
Old 11-24-2008, 07:33 PM   #23
msgross
msgross's Avatar
be careful with the sending unit. My mom truck (95) just got a new pump and the sending units break when they are old... hopefully yours won't//
The Garage:
Old 11-24-2008, 09:46 PM   #24
dailydragger03
Yeah thats what I was gonna log on and tell you today. I had to get in touch with a friend at the dealership about some parts because my roommate crashed his car today. That's reasonable considering it seems to be a dealer only part.
Old 11-25-2008, 12:10 AM   #25
53burb
53burb's Avatar
I forgot to ask the parts guy, but this isn't recommended to replace the wiring harness, right?? When I had my '99 replaced, I had to replace the harness, as well. I think GM has fixed this problem since then, tho.
