11-24-2008, 07:21 PM | #1 |
eaton disk brakes
has anyone done a disk brake conversion on a eaton rear end?
i have a 68 k20 without power brakes (for now) |
11-24-2008, 09:16 PM | #2 |
Re: eaton disk brakes
I started putting disc's on mine before I sold the truck it was in. I put Dana 44 rotors on it from a Chevy K-20 axle, 14 bolt disc brake brackets will work. The backing plate flange has the same bolt pattern as a 14bolt except the eaton's are fine thread bolts. Then you can run Dana 44 calipers and pads. Pretty simple. These are the brackets I used.
http://cgi.ebay.com/ebaymotors/14-Bo...3994QQtcZphoto
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
11-24-2008, 10:12 PM | #3 |
so just the same as on a fourteen bolt thats easy enough thanks alot!
11-25-2008, 10:07 AM | #4 |
Wait, I am confused, I bolt these brackets where the backing plate was, and I can buy Dana 44 rotors that will fit on the Eaton axle shafts? How about dually rotors? I have a C30 but the axle is the same only shorter. It needs new brakes so rather then fixing what is on there, it is about the same to do a conversion. I was about to order new parts for the drums but this look interesting.
11-25-2008, 11:21 AM | #5 |
Between Trucks...
Subscribed.
Beat it to fit, Paint it to match... |
12-07-2008, 05:18 PM | #6 |
I don't know about the dually part. The brackets would probably be different than a SRW axle and I don't know if Dana 60 dually rotors would fit. The rotor gets held to the hub of the axle with the wheel studs and the axle shaft gets bolted back on. For dually stuff, I would check a junkyard and see if there is some way to swap on a setup off a new dually axle.
