Old 02-24-2003, 04:43 PM   #1
Dropt72Shortbed
Dropt72Shortbed's Avatar
vin tag info?
my vin tag says the vehicle has a gross weight of 4700lbs as manufactured. above it says this includes driver and passengers etc. any idea how much theyre factoring is for everything extra? my truck is a 72 shortbed fleetside. was a 6cyl/3spd/ non a/c now a 350/350
i highly doubt my shortbed can be that much over 4,000 lbs im just wondering how they got this 4700lb figure.
also where is the vin stamped on the frame? i want to check to see if it matches my cab.
Dropt72Shortbed is offline   Reply With Quote
Old 02-24-2003, 06:13 PM   #2
crazy longhorn
Fabricate till you "puke"
The gross weight is with payload. My Longhorn states GVW 7500 lbs........but curb weight was around 4800. My guess (and thats what it is a guess!) your short bed probably weighed around 3500 curb weight(empty)... You should find a partial vin on top of the frame rail , in the steering box area......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-24-2003, 07:17 PM   #3
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
This is a pic previously posted by Longhornmail.
And yes, that dirty hand belongs to him
That's where the vin on the frame should be.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 02-24-2003, 07:22 PM   #4
crazy longhorn
Andy, you better scrub them grubby fingers up dude! The other longhorn(the crazy one)
Old 02-24-2003, 07:37 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
In the early 70's the camper craze had hit. Camper manufacturers were putting campers on their 1/2 ton pickups that were within the weight rating, but they were overloading the rear axle, making the pickups hard to control. So, the government changed the way load ratings were calculated. With this, a 1/2 ton pickup no longer was rated to carry 1,000 lbs. My 74 was rated to carry a load of around 700 lbs which included the driver.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 02-24-2003, 07:52 PM   #6
72CustomCamper
Take it to a local scale and get it wieghed for about $8. "CAT" is a nationally recognized and certified scale operator. Should be one near you somewhere...
My '72 weighs in at 4800lb, no payload, full tank of gas.
The 3/4 ton chassis adds alot as does the BB that has my front end almost dragging...
Truck originally had a 350 and the published weight according to WA DMV was 4238.
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454
'93 K2500 Suburban, Old 454 (157K)
72CustomCamper is offline   Reply With Quote
