Old 03-24-2002, 11:50 PM   #1
dion
72 Cheyenne
dion's Avatar
Post Is this a good Hydro Cam?
Duration .050 Int. 204
Ad. duration 270
Lobe spread 112
Valve lift .420
Cam litf .280
Restored 72 Cheyenne C20
San Diego, CA
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 03-25-2002, 09:55 AM   #2
MikeB
MikeB's Avatar
Post
It's a mild performance cam (assuming you have a 350) that will work well with stock intake and exhaust manifolds, and prox 8.5:1 compression. Peak torque is probably around 3000 PRM, with peak hp at 4000. You will have a smooth idle and lots of low end torque. For comparison, here are the cam specs for the very mild 350 "Goodwrench" crate engine:
Camshaft lift: 0.390” Int/ 0.410” Exh
Duration @ 0.050”: 195° Int/ 202° Exh
Lobe center: 115 degrees
The more agressive exhaust lobe compensates for "lazy" stock exhaust ports.
For some really good cam info, that actually takes engine size into consideration, check out: http://www.crower.com/misc/m_cat.shtml
Then go to Page 24.
MikeB
69 C-10 Fleetside, mild 383, Dart Iron Eagle 180cc heads, Crane Energizer 266 cam and 1.6 roller rockers, Edelbrock Performer manifold and 600cfm carb, HEI w/ MSD components, 1986 front spindles/disc brakes, Vintage Air in-dash, lowered 2"/3".
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 03-25-2002, 10:15 AM   #3
Frank_Zeller
Frank_Zeller's Avatar
Post
Mike, do you know the cam specs for the GM 305 create motor?
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 03-25-2002, 10:52 AM   #4
dion
72 Cheyenne
dion's Avatar
Post
Thanks Mike.
San Diego, CA
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 03-25-2002, 12:45 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
Post
I have a simillar cam in my truck's 350, 204 intake/214 exhaust duration @.050 lift, and the valve lift is around .444/.443 if i remember correctly. I am happy with it, it has alot of power (about 300 horses in my engine) and great low end tourqe. From 2000-3000 rpm, in the highway cruise RPM's, it has plenty of power for the pulling hills.
Lucas
drop_shift@hotmail.com
My Daily-Driver: '72 Chevy LWB Custom/10. Rebuilt 350, 300 HP thanks to a few go-fast goodies. Ochre with a white top. Future plans include a frame off restoration, and maybe a blown 383.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
